Watch this for final word on which fuel to use (Hint: Premium fuel matters)
Hahaha many folks here bang their heads to the fuel tanks now 😜 😜 😜
Nothing to prove here with this video.
Can be entertaining or education or whatever you please with ;)
My choice is just following what I read from fuel door information: Premium fuel only ( hahah again t3lcfe ? ) lol while typing this 😜
This may interest some.
"87 vs. 91 Octane Fuel: STILLEN’s Kyle Millen reveals how fuel octane impacts the Tacoma’s 2.4L turbo engine, showing a 20-horsepower gain with premium fuel. Learn about octane ratings, real-world dyno results, fuel costs, warranty considerations, and why 91 or 93 octane is essential for maximum power, efficiency, and engine longevity—especially with TruControl or other performance upgrades. Don’t miss this must-watch guide for Tacoma owners!"
I think it is all about gas mileage ! Toyota is concerned the the poor mileage ratings for the Land Cruiser will affect sales so they tuned the engine to take advantage of the better mileage achieved with premium fuel . And that's all there is to it!
Welcome to the asylum allanvt.
By the way, there are types of knock that cannot be prevented by retarding ignition timing. Most common example is when the engine is under heavy load at low RPM. There are alternatives, like alternating valve timing or air/fuel mixture, but some of these can cause catalyst, valve or injector damage over time.
I would expect that the ECU would ask for a downshift, ask for electric assist, or limit boost in a low speed, high load situation. My experience with the T24 (non hybrid) in our Highlander at work is that it is still very aggressive in downshifting rather than just adding boost when the vehicle is loaded and the driver is asking for acceleration.
Anecdotally, my GR Corolla will not make over 6-7lbs of boost until it has hit a minimum threshold of engine temp. The ECU knows that ragging on a cold engine is bad, so it limits boost until it is warmed to some minimum. If I'm lugging along at 35mph in top gear, it also won't give me full boost if I mash it. It will hold the boost low until the revs have reached 2200RPM or so despite the turbo easily being capable of making boost.
So could one expect lower mileage on regular instead of premium gas? I should try an experiment one day with my current car & see if mileage improves with premium. It sounds like the premium vs regular gas argument could go hand in hand with the mileage not up to EPA numbers debate.
Engine compression is high enough (11.1) that it can knock without boost. Engines with compression ratio in this range requires 96 RON fuel.
Compression ratio vs fuel octane
Downshifting is an option if it is already not at 1st gear. Towing, crawling etc, are potential situations that the vehicle may be at 1st gear with high engine load. Also, if the engine gets hot enough (i.e extended load) it will start to knock regardless of engine speed due to hot spot autoignition.
That, and the EPA numbers were determined in a 1958, with skinnier, and smaller tires (less rolling resistance), and NO ‘air dam’ on the roof like the FE LC’s.
Reactions: MJE
I switched to regular two tanks ago. So far, my indicated mileage is down 0.1 mpg.
Reactions: MJE
Here's Japan-based Toyota Chief Engineer Sheldon Brown on the subject of why premium gas was recommended for the Land Cruiser and not other trucks in the line up.... To me, his comments seem reasonable, logical, and scientifically sound. Minutes 4:27 - 9:50.
Ah ok. So I didn’t even think about that. If the vehicle is offered with the same powertrain across trims, they’re allowed to test it with the most advantageous one?
Ah fair enough, so likely not a major determining factor for mileage then.
It would seem so..
The Tacoma and 4Runner have the bandwidth in their ECU parameters to run on 87 with the same compression ratio. The Land Cruiser would have the same ability to adjust timing to accommodate.
Again, you cannot adjust ignition timing prevent pre-spark knock, it only works for post-spark knock. There are ways to prevent pre-spark knock, but unless we can confirm every parts from cooling to valves to catalyst are 100% identical between LC and Tacoma/4Runner, it doesn't suggest equivalency.
More food for thought. There is a thread going in Tacoma forum about engine becoming less noisy with premium.
Well, geezy peezy.. Maybe that’s why Miss Daisy doesn’t make a lot of the noises that everyone complains about. She only gets 93 octane ethanol free fuel.
The parts catalog has a feature where I can click "where used" and it will show me all the other models that use that exact same part number. Radiator = same, water pump = same, valves = same, catalysts = same, cams = same, VVT gears = same, ignition coils / plugs = same, pistons = same, crank = same, rods = same. In fact, the service part for the entire longblock is shared between 4Runner and Land Cruiser.
Canvasback
