Volk/rays wheel weights/pictures
Where do you guys buy Rays wheels? I’m interested in how much the D108’s cost… but not having much luck with the local β€œdealers” responding to me.
I’d check with showstoppers or vivid racing. Stock for our LC’s is low right now tho. Next shipments come in end of July/august as far as I can tell.
Still no one running rays 05x wheels huh?
No, but here’s my client on Bradley Forged 18x8.5 +40
Anyone know if 17x8 et20 would acceptable? Bradley and Rays both have that size. I’m assuming yes as 18x8 et20 seems to fit.
Does it fit without rubbing? I’m not a hardcore off-road enthusiast but I detest any form of rubbing. Had too much of that with other modified cars.
Depends on your tire size. 285/70/17 on 17x8 or 17x8.5 +20 offset will not rub but it will have some tire poke
Yes, it is Pressed Graphite. +38 offset has zero poke. Additional picture showing side profile for your reference.View attachment 38086
Hi, I’m trying to figure out my Volk purchase. I’m looking at the TE37SB and the vendor is suggesting 18 x 8.5 with a 22mm offset. He stated this setup would be flush, which is what I’m looking for. What size wheel did you go with and where did you source the lug nuts and hub rings? Thanks.
IMO you should go +35 or greater if you want flush. The TE37 Large PCD model has fitments for LCs. Check out the high offset (>+40) wheel threads in this forum. Rays sells M14 truck lug nuts (as do others) in a 24 pack, but no hub rings because they're not needed. Check out Project KICS if you want fancy JDM lug nuts.
Thanks. And yeah I was thinking to go larger/increase, in terms of offset. I don’t need fancy lug nuts, though I understand my original ones won’t fit. I’ve been recommended to use rings though, as I understand the lugs should not be holding the bulk of the wheel weight as they are not meant for that force. This is what the hub is for and that relying on the lugs for this could cause vibration and loosening of the lug nuts. Anyone running rings or no rings? Appreciate any additional thoughts.
I may have not stated that correctly. I meant the hub ring will keep the wheel centered, and avoiding vibration.
If you think the rings are needed, then why buy expensive Rays or other JDM aftermarket wheels when they don’t even provide them as an option?These manufacturers do make center caps as an option if you want a more finished look. You can get fully hub centric Toyota or Lexus wheels for a lot cheaper. There’s a few other aftermarket wheels that are hub centric like FN, BC Forged, TWS Forged.
Hey guys,
We carry Ray's/Volk and would be happy to assist anyone looking to grab a set for their 250!
I hope everyone sells lots of sets of these TE37 30th Anniversary Editions so the price comes down :). The white might look a little better on a Traildust or Heritage blue though imo.
:love: My goodness that looks good!
The answer to your question, sir, is weight. No wheel I’ve found offers this degree of weight savings. The rings will keep them hub centric. Yeah, it’d be ideal if Rays offered them, however there are aftermarket options. However I do appreciate your perspective. Thanks.
