Vibration from motor to wheel?
I have motor vibration on steering wheel too, sometimes, during acceleration, when turbo is running around 30%. I am fine with it.
If you're used to only driving silky smooth 6 and 8 cylinder engines, you probably just need to adjust your expectations. If it's significantly worse than other 4 cylinder engines you've driven, there may be an imbalance.
Unfortunately, this isn’t really a refinement issue. I’m currently retired, and the vehicle I’ve been using for years is a Ford Transit Custom van — mainly to carry my trial motorbike, parts, and stuff to restore my old cars. Neither this van nor any of my small collection of classics (a 1991 Land Rover Discovery 1 and a 1963 Land Rover Series 2) have ever had this kind of problem.
Actually, I don’t remember any car I’ve owned or rented showing this sort of vibration. It feels kind of like the buzz you get from an electric drill when it’s running, but not as strong. It’s uncomfortable, and after about an hour of driving, my hands start to go numb.
Technically speaking, it’s a pretty high-frequency vibration — higher than what you’d get from tire imbalance — and it shows up as a twisting motion in the steering wheel. It’s like the wheel keeps turning slightly left and right, really fast.
My guess is that it’s some sort of resonance issue in the steering column or assembly, maybe caused by vibrations coming from the frame area where the steering box is mounted. But that’s just one of my theories.
Check with dealer to know what it is. Manufacture will cover all parts and labor. Dealer will be happy to warn that business
I'm experiencing what I think is the same issue. Picked up the Land Cruiser last week - and noticed immediately. Noticeable vibration in steering wheel and floorboards when accelerating between 1500 and 2500 RPM a buzzing sensation. Vehicle speed doesn't matter, has nothing to do with tires, it's the engine speed and being under load that's causing the vibration (so engine or drivetrain?). There was a also a chatter vibration at certain times when vehicle was idling. I got under and checked the exhaust hangers (rubber donuts that suspend the exhaust) and all were intact and the exhaust seemed to move freely without touching anything (which would cause vibration). While under the vehicle noticed the heat shield on the fuel tank was kinda loose and chattered- pulled at the edge to bend slightly and chatter went away. Vibration on acceleration remains.
The engine sounds like a 10 year old Corolla. None of this is what I would expect from a 70K vehicle. The Land Cruiser we test drove did not have the vibration and the sound was not as noticeable. Dropped it back at the dealer yesterday and it's getting checked out now - will advise what they say, but I have a sinking feeling they will assert its normal or cannot be reproduced.
New 2025 LC owner here. 300 miles on the vehicle.
I noticed upon acceleration I can feel the motor vibration through to the wheel. It smooths out at higher speeds.
Is this normal? Didn’t think a $70k vehicle would respond this way. Overall it is a great vehicle. This just bugs me
You might ask the dealer service department to check your fuel injectors...a faulty or clogged injector can give you the same symptoms you are describing.
I feel it too, in the steering wheel, floor, brake and gas pedals, and seat. What has helped me is putting some CLD (Constrained-layer damping) on the pedals and floor. It helps a bit when I put some on the intermediate steering shaft on the outside that connects the rack the steering wheel. I wonder if i can take off the plastic pieces that covers the steering column and put some in there.
This is a resonance vibration issue that they never figured out, it's also bad when the engine idles too. I had a 5th gen 4runner and it didn't have this issue.
Just curious OP did they request to keep it overnight or did you drop it off late in the day?
Brought it to dealer mid-day - they kept it overnight. My contact (Sales Manager) was out today, and no call from the service center.
Welcome to the asylum.
Mine vibrates a bit when lugging in low gear while the electric motor is helping significantly. Seems normal considering what is happening, but i dont have anything rattling or concerning occurring while this happens. If i watch the power meter display, the vibration coincides with significant traction battery deployment. Perhaps that's what you're noticing.
I’ve got the same thing. Drives me absolutely crazy.
I’ve proven it is drivetrain, somewhere. During the moment it is doing it, I’ve kicked it into neutral and it immediately goes away.
Adding more throttle makes the trans kick down and it goes away.
It’s a bit disappointing really.
New member here! I just purchased a 2027 premium and I'm also having high frequency vibrations in the floor and steering wheel under load, around 1500 rpm. I live in the mountains so I'm driving under load and low rpms all the time. The vibrations are very tiring. Did you guys find a resolution to your vibrations issues? I would really appreciate some help here. I plan to take it to the dealership next week and I'm afraid I may get the dreaded 'it's normal' explanation. Many thanks.
Hello
In my case, I feel a vibration through the steering wheel when accelerating, for example when going uphill. I would say it occurs when the engine is producing high torque. The vibration is not noticeable on the dashboard or anywhere else in the interior of the vehicle; it is only noticeable through the steering wheel.
One of the first things to check is whether any of the steering wheel adjustments are at their limit or fully extended. In my case, when I moved the steering wheel slightly further out, the vibration became less noticeable.
On my steering wheel, the vibration was felt mainly through the rim, not through the centre. I made some measurements using the accelerometer in a mobile phone, and it seemed that, in my case, the vibration was rotational, or torsional, rather than a simple vertical or lateral vibration.
I suspect that the problem may originate from a vibration in the engine or drivetrain, and I have even wondered whether this could interfere with the operation of the electric power steering system.
I eventually built a split flywheel that clamps onto the steering column. The flywheel incorporates rubber bushes that support the split weight. It is effective, but it is quite heavy, and I am concerned about putting that much additional weight on the steering column.
At the Toyota service centre, they gave me the rather ridiculous explanation that this is simply a consequence of the engine's power.
I sent Toyota Spain several pages explaining the problem, together with my vibration measurements, but I don't think they even looked at them. They simply referred me back to the dealer.
My vehicle is a European-specification, diesel, non-hybrid model.
@Arnau, I hate hearing this.
The US versions have Toyota Safety Sense 3.0?, which among other things, can help steer the vehicle while driving. Can you turn off the ‘steering assist’?
Thanks for the response. I really don't think the vibration has anything to do with the Toyota Safety Sense. It really feels like some sort of very high frequency harmonic resonance within the drive train that is not isolated from the cabin. The vibration stops when shifting into neutral. Apparently this issue only occurs in some hybrid Land Cruisers, but not all. I'm certainly not a mechanic, but I think it might be helpful to observe the drive train with a Dynamometer, but I'm sure the dealership does not have that kind of equipment. Unfortunately, it appears that no one has a fix or solution to the problem yet even though the problem has occurred across multiple model years. It's hard to believe that Toyota hasn't fixed this yet!
Mine rarely has any vibrations that seem excessive, and I've been towing camper through mountains all week.
Have you been able to drive another '27 LC to compare against yours? And i would not necessarily trust the dealer's response. Need another opinion and read the lemon law (again?) For your state.
@Arnau can you check your motor mounts to see if they vacuum connections on them like the US Spec does? Just interested to see as these are supposed to cancel vibrations out during different RPMs and Loads by adapting the hydraulic valving inside to increase and decrease the available fluid volume acting upon the dampening effect.
