Vibration from motor to wheel?
PHenderson
South Carolina
2025 Lc
New 2025 LC owner here. 300 miles on the vehicle.
I noticed upon acceleration I can feel the motor vibration through to the wheel. It smooths out at higher speeds.
Is this normal? Didn’t think a $70k vehicle would respond this way. Overall it is a great vehicle. This just bugs me
Reactions: MJE
First off, welcome to the forum! This said, sad to hear you have an issue out of the gate. It is possible there is a miss in the engine? However, presumably no codes, which undoubtedly would be so if there was a cylinder misfiring, so the vibration might not be as you suspect, from the motor.
First off, welcome to the forum! This said, sad to hear you have an issue out of the gate. It is possible there is a miss in the engine? However, presumably no codes, which undoubtedly would be so if there was a cylinder misfiring.
Thanks Nuke,
No miss…just a transfer from motor through to wheel. Maybe normal?
Thanks Nuke,
Sure doesn't sound normal to me! Just a thought, have you checked the tire pressure? Many report their dealer failed to reduce the shipping tire pressure to where it is supposed to be.
The engine seems to vibrate below 1,500 RPMs. I know 4 cylinder engines aren’t the smoothest running engines.
Presuming premium fuel? Top-Tier? Some have reported rough idle with regular gasoline.
PHenderson, Welcome to the Jungle!​
Maybe a wheel out of balance as the engine isn't connected to the wheel (I assume steering wheel).
There is a vibration felt at certain rpm’s, like a lugging sensation from being in too high a gear.
Some of the online reviews called it out.
I can feel something similar to that at like 1,300 rpm’s. I always thought it to be common nature of a 4 cylinder. I just give it a little more throttle causing a downshift and vibration goes away.
Not normal, mine is smooth as glass at all speeds.
Looks like a couple others raised this too.
I can barely feel it in mine, not sure I would have noticed it if it wasn’t called out in the review I watched.
Front end alignment or tire balancing?
It only happens at certain low rpms, my assumption is when it hasn’t down shifted yet. Same sensation on a manual car or bike if you don’t downshift.
Definitely an engine feedback not an alignment issue - but it’s subtle and not something I’ll always even notice.
Yes I noticed it when driving off the lot. It's pretty apparent so much so that my front passengers notice too. Some days its OK. Other days its pretty bad and vibrates my driver side door. Worse when under load like going uphill. Less noticeable at high speeds. Might have gotten a lemon. I'll bring it up to dealer at 5k appointment
I feel vibrations when I accelerate spiritedly. A number of YouTube reviews have mentioned the vibration, stating at this price point it should not be allowing engine vibrations to be transmitted through to the steering wheel. I personally don’t find it significant enough to be a bother.
I'm noticing the same thing - while accelerating or climbing hills, there is a noticeable vibration which can be felt in the steering wheel. It seems to be correlated with turbo boost (that boost gauge is proving itself useful!). It's mildly annoying. Any ideas? Thanks all.
My car has this annoyingvibration in the steering wheel, especially when I’m going uphilland accelerating. It’s a higher frequency than the one you’d getfrom unbalanced wheels. The dealer already balanced them, but itdidn’t change a thing.
The vibration isn’t super strong, butafter driving for about an hour my hands start to go numb. It’sreally not acceptable for any car, especially one in this pricerange.
When I asked the dealer about it, they said it’s “justthe engine applying power,” which is obviously nonsense.
I’m a design engineer,and I’ve worked on railway components with very tight vibrationspecs. I’m not exactly a vibration expert, but I know a bit aboutthe topic.
So, as a first step, I used my phone with a vibrationmeasurement app and strapped it to the steering wheel rim with somerubber bands. I found that the vibration is rotational there’s novibration at all in the center of the wheel.
Then, as part of thetest, I attached a 0.5 kg weight to the rim of the steering wheel,and the vibrations almost completely disappeared.
I’ve alreadysent a report to Toyota Spain and I’m waiting for their response.Clearly, the dealer has no clue about this kind of problem.
If you're used to only driving silky smooth 6 and 8 cylinder engines, you probably just need to adjust your expectations. If it's significantly worse than other 4 cylinder engines you've driven, there may be an imbalance.
Was this problem ever resolved to your satisfaction?
