One more drive and you get to call it normalI confirm I had 2 drives today exact same road and weather conditions and with PDA off the Temp stayed in the center
Outstanding!I confirm I had 2 drives today exact same road and weather conditions and with PDA off the Temp stayed in the center
It’s the only way I could imagine interpreting the graph! The more I think about @ultane ‘s comment a while back, the more I agree Toyota should have just used an old-fashioned warning light to indicate when the temp exceeds normal ranges, without any graph.Outstanding!
Looking at your picture, Toyota has given us a graphical hint possibly- operating temperature(s) in white shouldn't extend to areas beneath red?
... If they built the display to show that? ...
edit: It IS the way I would interpret the gauge.
In the present state of information on EXACTLY how this display shows what, I agree.It’s the only way I could imagine interpreting the graph! The more I think about @ultane ‘s comment a while back, the more I agree Toyota should have just used an old-fashioned warning light to indicate when the temp exceeds normal ranges, without any graph.
Oh I totally agree with the value of good gauging. In fact, I’m fairly satisfied with the way it is as-is (though I’d like even more info). But looking at this from the lens of a mass consumer product (see the massive sales of the latest generation), I think for your average buyer (who is neither a Land Cruiser enthusiast specifically or automotive enthusiast generally) a simple warning light would be better. The additional information probably creates false concern for more owners than those who are able to intuit it and make practical use of.In the present state of information on EXACTLY how this display shows what, I agree.
If there was underpinning Toyota documentation that was PUBLIC and that information showed that the gauge operated somewhat the way we're estimating, I'd disagree- good gauging provides real-time guidance and therefore warning. Before damage if you're watching hopefully. A better widget that showed high/low limits or the actual temp in numbers would fix the issue. A software change....
My new mantra- Toyota are you listening?
I wasn’t asking for an idiot light.. I was pontificating that Toyota would replace the gauge with an idiot light, to silence all of us, who have our worry beads out, and vigorously give them a workout.. daily.. unfortunately the facetious font isn’t available to me..- good gauging provides real-time guidance and therefore warning. Before damage if you're watching
Keep an eye on it. Toyota service re-enabled it for some reason during routine maintenance.I confirm I had 2 drives today exact same road and weather conditions and with PDA off the Temp stayed in the center
Stug4 - Sorry you had an issue. Was that like a 4.7% grade? No doubt that’s a climb, but doesn’t appear excessive. Was the tranny hunting in auto so you went down to 1st gear?I recently climbed 2,000 feet over an 8-mile paved road accessible to standard passenger cars. The vehicle was not loaded, carrying only two adults and minimal gear. I kept it in 4HI, manually locked in 1st gear (1M), maintaining around 3,000 RPM the whole way up. During the drive, the dashboard temperature gauge rose to about 80%, and my OBD2 reader logged a peak transmission temperature of 240°F... It looks completely weird.
Similar 10-15mph climb in 4HI auto heated up transmission to 225F in 5 minutes and I had to switch to 4low. My point is that manual mode in 4hi did not help as I expected.Maybe let the LC choose the appropriate gear, or use 2nd or 3rd.
I would think manual mode in the situation you described would hurt, not help.Similar 10-15mph climb in 4HI auto heated up transmission to 225F in 5 minutes and I had to switch to 4low. My point is that manual mode in 4hi did not help as I expected.
