Toyota Recalls 82,000 Vehicles Because Driver Displays Can Go Blank; 2024-2025 Land Cruiser included
Sorry but I’m pretty sure this is AI nonsense. Why would the software “recalibrate the internal audio signal levels (gain staging) sent from the head unit to the vehicle's factory amplifier”? I’m happy to be educated but I’m pretty sure this is a hallucination.
Having been part of cars going through their initial calibrations on the production lines, this doesnt surprise me. There are hundreds of setpoints and tests performed when the car is being brought to life. Could also be AI B.S too. You'd probably have be a toyota process engineer to know for certain.
My gut tells me that is a pretty big stretch also.
Actually, no. My little Fiat definitely retards the gain when it senses excess volume.......System obviously has a built in clipping sensor so amps or speakers don't get fried. Far more sophisticated than old school hard clipping shut off or breaker popping.
Modern vehicles often have electronic adjustments of the audio system automatically performed “on the fly” by the vehicle- speed dependant volume/equalization is common today (and included in the Land Cruiser). The disbelief I have with the AI content posted is specifically that this update from Toyota delves into anything related to amplifier gain 😉.
The context of what we’re discussing is not whether the amp has gain limiting, but rather whether the software update for the screen glitch would change audio amplification signals. Seems highly doubtful to me.
There is a multimedia component to the software update (see image captured by izzysanchez), though we haven't been given specific details. I'll find out soon enough how it relates.
So it turns out that I did not have a complete update. Part 1 of 2 was only applied over the air. The dealership flashed the complete update, but it still doesn't explain why I had that noise - it will remain a mystery. 🤷‍♂️
When I got in my Land Cruiser this morning it had a prompt about a software update being available. I think it said for the recall. Anyone else get that? I was on my way to the dealer for an oil change and the recall SW so I dismissed the message, I should have taken a picture.
I believe it is. If you go back into the infotainment section under "updates" you can download part 1. You may need to connect your vehicle to WiFi to download part 2 and install. If the dealer performs it then it will disappear as an available update.
Did the update and now my screen is split in half. Is anyone else experiencing the same issue
Whoa, no. Were both part 1 & part 2 of the software update installed? I found out that I only had installed part 1 after going to the dealership - they took care of flashing part 2.
Nope didn’t have that issue! I’d take it back, they should be able to cure at no cost to you.
Both parts installed and only visible on the rough style of the dash
I might be missing something, but that just looks like the single gauge with widgets option.
Have you tried going into your gauge cluster settings and changing it back to the two-gauge option?
