SLEE – ARB Compressor Mount now available [installed pics added]
do we know if this fits the new brushless dual from ARB ( CKBLTA12 )?
I assume it does, because Slee offers the bracket and the brushless compressor as a kit.
I'm sure it's been discussed and dismissed, but would it be possible to build in an on-board unit the way it's done in the GX550 Overtrail? Or is this ARB approach equal or better?
not possible. the 2025 GX Overtrail has the compressor in the spot where the car battery is on the LC.
Nor would I want a compressor mounted on the interior of the vehicle where loads of stuff impedes access.
I am sure anything can be done, but the compressor that come with the GX is adequate but not nearly in the same class as the ARB especially on the new TWIN BRUSHLESS.
Reactions: GC3
There's only so much unused space in the LC. Now if you wanted to relocate your jack, that would be a most excellent spot for an on-board compressor. If you wanted to remove your front cubby compartment tray, there is a ton of room in that location. There is a decent sized space in the driver's side "D" pillar. But without relocation something else....... under-hood or frame mounted are just about the only options.
Reactions: GC3
