Finally spent some time trying figure this out since no vendors are making a bracket for this location. I picked up the ARB Brushless Single Air Compressor as I did not want a dual and did not want it mounted under the hood. Fits perfect and plastics all go back on perfectly. I plan to just remove jack plastic cover while in use for heat reasons.
So far, I was able to get brushless mounting bracket inside jack bracket by drilling 2 holes and then mounted the pressure/app module on the bottom side with only having to drill one hole. I had to order some fittings and hoses from ARB so will finish up install this week and post more pics.
I’m also running Garmin Switches (one inside and one under hood) for device control including the compressor. I’ve used these Garmin Switches on my last vehicle and love them since they integrate into CarPlay for control.
![[PLOMOR] Share Your Journey: LC250 Scenery & Builds Showcase](https://www.landcruiserforum.com/data/files/featured_images/47/featuredimages_6b79e9b7744cbd73.webp)
