Good move to contact Beatsonic.
Stock speakers rated 4 and 8 ohm and in parallel have an "AI" calculated 2.66 ohm resistance. Even these could well be trouble for a 4-8 ohm rated Beatsonic. Then could cause trouble for the factory equalizer that is downstream in circuit. I reckon it would would not affect the head unit, but do not know. Two aftermarket 4 ohm speakers lower resistance down to 2 ohms. Zip zap danger.
Crutchfield had the parallel wiring in the Install Notes, however multiple advisors missed that or didn't understand and encouraged me to install speakers that would cause these problems. One tech support person even flatly denied that two speakers in parallel would lower resistance. The next tech support person sighed and said yes it definitely would. Several Crutchfield folks have given advice that still stands as good and has been helpful, but about half of the suggestions I later discovered were misguided or even risked damage.
Grok Ai has been helpful as a "mass word processor" review tool for ideas or inquiry tool. It does make often make mistakes, but has raised new ideas I hadn't considered and so saved me from mistakes a few times.
It could be that simply installing a 4 ohm front door and 4 ohm dash speaker could stress the factory head unit and cause that to fail. Probably very expensive to replace.
I believe the Beatsonic powering upgraded front door speakers without dash speakers connected would sound great and have zero risk. I ran new door speakers on the factory head unit without the dash connected for a week and that sounded much better than stock and worked fine. Beatsonic increasing wattage from ~12.5 to 25w I am guessing would be quite noticeable in enriching the upgraded speaker sound.
That is my backup plan for good sound much improved over factory. I am aiming further with a JBL DSP4086 amp with 40w x8 channels with DSP tuning for speaker time alignment, crossovers, volume balancing, and cabin acoustics EQ correction. People online says DSP tuning takes it to a whole new level. Six factory speaker location, maybe a center dash, and a powered underseat sub (JBL BassPro SL2 fits) for a lift up in sound quality, at a fair price, for many years.
This evening I just finished new wiring install to send the factory signal to an underseat amp, then send the amped signal back into the factory speaker wires to power the 4 door speakers. New speaker wire was added alongside to power the corner dash speakers. It actually went pretty smooth with using a beatsonic BH10 wiring harness. Without a interim harness, I would have a high risk of messing up the factory wiring harness, big problem... Used Posi-lock connectors to connect wires, they were a great help and are now secure.
I was impressed how smoothly the dash trim comes off and goes back on.
The next step is to find a good ground for the amp and powered sub. The seats may need to be unscrewed and tilted back out of the way. Power wire routing seems to be worked out.
A middle complexity option was the Kicker 47Key200.4 auto-DSP amp powering 4 door speakers on factory speaker wiring, but I figured if I'm splicing and rerouting the factory signal, I might as well try to place new dash speaker wire, and that worked out to be easy. The 8 channel JBL amp also provides for a sub, and center dash if it seems worth it.
