Running Boards
MJMarroni
4
0
North Andover, MA
2024 LC First Ed
Has anyone either replaced the rock rails on a first ed with running boards or have added the Toyota facory steps? I would appreciate any thoughts / advice. Thanks!
My guy at Toyota said I'd have to replace side body parts and sent me to CapWorld. They said that they do not have any brakets that would fit a 2024 FE. If you could point me in the right direction that would be great.
The running board and rock slider mounting points are both identical on every trim of the J250. The only consideration is that if you get the illuminated running boards, there won’t be a plug for them on the 1958 trim.
I’m not sure what bracket they mean. It just bolts into the factory mounting points (which again, are identical for every trim 2024 or 2025).
I did this myself and am not handy. No additional items needed. Lc has all the bolts around screwed into the frame that you use on the running boards.
