Was the sound reduced at least? Did you take any pictures of where you put the material?
No, I didn't take any pictures. I slapped some on the rear of the hvac control trim, then across the inside of the lower trim, jammed some into the pax side between the trim and the inverter/box, and laid a piece across the top of the box. There is a vent on the driver's side, can't cover that up.
No it wasn't reduced any noticeable level, maybe a touch. You would have to take apart the whole center console, probably line everything with MLV, and who knows if it would work. What I have is just too thick to get into a lot of areas. I concentrated on the rear and pax side since it sounds to me as if that is where the majority of the sound is coming from, I was hoping for a noticeable sound reduction at least, but didn't get very positive results.
Perhaps it is slightly lower when moving faster than a crawl, may have taken some of the higher freq out. I'll need to give it a few days, I'm obviously paying more attention than I normally would.
Update: So after a few days, I figure my half ass insulation job has knocked the sound down to that of a idling desktop computer fan (which is what it sounds like), definitely took a decent amount of the high pitch sound out if you are sitting in the front. Sitting in the back, it could still be annoying. One it probably better off just tossing a jacket over the rear of the center console, which knock the sound out completely. LC hasn't caught on fire yet, which is a good sign. I am still of the opinion that it is a fan, if it is, Toyota should spend the extra fifty cents and install a quieter fan.
