Man I simply can’t get these brackets under the sway bar no matter what kind of angle I take.I installed mine today. A few quick notes, I’ll write more on my build thread probably.
- Clearance is decreased by 9/16” according to my laser distance thingamajig measuring to the center of the low point.
- You do need a short/small socket for one of the brake line bolts. I got it started with a 1/4” drive socket, then removed and started it again with a wrench.
- Unlike the directions, it seems like you need to hook one end of the bracket under the sway bar, then carefully(!!!) move the brake line out just enough to get it under. The directions seem to say you would get it under the brake line first, but I could not figure out any way to get it under the sway bar if I did that.
