Method Race Wheels Hub Ring Installation (& Hub Bolt Thread Repair)
RideWithYanu
🏆 LC of the Month
⭐ Supporting Member
PNW
2025 TJH250L-GNZAZA
I've had a noticeable vibration on my 2025 TJH250L-GNZAZA above roughly 65 mph ever since I installed my Method 703 / MT Baja Boss A/T setup. I chased it the way you'd expect — multiple rebalances and a couple of realignments — and never got rid of it. Eventually I chalked it up to the cost of doing business on E-load Mickey Thompson Baja Boss A/Ts, which are close enough to an M/T that a little highway NVH seemed like a fair trade for sidewalls that survive sharp rock. Then @cruiser_ss396 put me on to hub rings as a possible solution. At $22.49 shipped for the set of 5 rings, it was an easy decision to give them a try - and after installing them the wheel vibration is massively improved; it's almost gone!
The short version of why they work: Method bores the 703 to a 106.25 mm center bore so one casting covers several Toyota hub sizes, but the J250's hub pilot — the machined boss the wheel slides over — is only 95.1 mm. That leaves about 5.5 mm of air all the way around, so nothing locates the wheel except the six conical lug seats. You hang the wheel, gravity drops it onto the studs, and the lug cones have to drag it back to center as you tighten. When they don't quite manage it the wheel runs eccentric — off-center — by half a millimeter or more, and on a heavy assembly that is brutal: 84 lbs of 703 and E-load Baja Boss sitting just 0.5 mm off the axis of rotation is equivalent to about 85 g of balance weight, roughly ten times what a balancer calls good. The rings are 95.25 mm ID / 106.25 mm OD sleeves that fill the gap so the wheel references off the hub instead of the studs, which cuts worst-case eccentricity to about 0.075 mm. They carry no load, though — clamp force from the lug nuts still does that — so lug torque still matters.
Install was super simple (though crossed threads on one of the hub bolts added some time and labor).
  1. Remove each wheel
  2. Insert each hub ring into the inside of the wheel
  3. Re-mount each wheel, tightening in a star pattern to precisely 131 nm of torque. I use a Quinn 58706 Digital Torque Adapter to make it easy, and my approach is to tighten each nut to 80 NM in a 1-3-5-2-4-6 pattern, then around again in same order to 131 NM each. After 100 miles I re-checked torque on each bolt (none had loosened)
Unfortunately, I recently made the poor choice to have my local Toyota service center perform a tire rotation. As such, when I went to remove the wheels to install the hub rings, I found that several bolts were cross-threaded; one was particularly bad, and I knew I had a problem when the nut removed with a bunch or curly metal shavings.
My first course of action was just to replace the damaged bolts, but after realizing I needed to fully remove the brake assembly first, I decided a thread chaser die was good enough. Note the bolts are M14 with a 1.5 pitch.
I worked the die backwards and forward on the bolt until I could fully tighten and loosen it with two fingers and minimal resistance. Then I took all 30 lug nuts (including the 5 security nuts) to the vice and ran a male thread chaser die into each one until they each had a smooth action when tried on the test bolt.
I highly recommend this product to any owners of the following Method Race Wheels: 312, 314, 315, 316, 318, 321, 323, 701, 703, 704, 705, 707, 708, 709-HD, 710-HD, or 712 with a 106.25 mm bore.
References:
  2. Insert each hub ring into the inside of the wheel View attachment 79115
References:
So many armchair experts who will quickly assert (emphasis in the first 3 letters) that well torqued lug nuts assuage any hub spacing issues. Glad to see a practical testament to the contrary. This is the only reason why the GX OT, Pro BBS and JAOS were my only real contenders, as well as a very temporary look at Icon because they actually make a hub-centric fitment. IMO, spacers are a no brainer if your wheel is not. Good writeup, as always @RideWithYanu
Thanks! Yeah and these certainly don’t fully cover all the benefits of a true hub-centric wheel, but they are a massive improvement in the install-alignment area.
I was scratching my head on that little vibration and when Discount mentioned these I was extremely skeptical. I honestly never ever gave it a second thought in all my years. This was mostly due to never running aftermarket wheels on much of anything except muscle cars. Discount balanced, rotated, road balanced again and then said we want to try this first before replacing tires. I said well as long as you buy them, pay for the shipping it’s no big deal. Then I found out the price…..:rolleyes: and thought to myself well crap. I figured they were going to be some $100 to $200 price tag, not $10 :cool:
I have done about 2500 miles of vibration free driving (just returned from a 1,000 mile
Road trip). Such a simple fix for an annoying problem that’s as you said, many probably live with.
I'm a lucky one here, I guess. I run 703's spring to fall then 318's in the winter and I do not use hub rings. Method Lugs. No issues to date with 11,000 miles.
Most aftermarket wheel manufacturers don't sell hub rings for six-lug LC250 fitments. Either they all don't know what they're doing, or we've all been conned into buying lug centric aftermarket wheels lol.
Good call and good work here! Replacing the studs is much more involved than what you thought.
You could probably remove the studs from the axle flange but no way to press the replacements in due to available space and backing plate design.
You have to remove the axle from the hub, which means draining the diff in order to remove the backing plate, hub and axle assembly off the vehicle as a whole along with the brakes being removed as well. There is a C-clip on the axle behind the hub and bearing assembly and the hub is pressed onto the axle. This requires some specific special tooling to do properly. Lots of single use parts that need replaced when doing this job. Once the axle is pressed off the hub and backing plate, you'll now have the room to replace the studs.
Good video here detailing what is involved, quite the pain in the rear. I'd make it a point to ensure when removing the wheels that the lug holes in the wheels never drag across the studs under the weight of the tire and rim. That's what it looks like the dealer did and damaged the threads near the end and just used the lug nuts to chew through the damage. They likely didn't even notice since they all use rattle guns.
I had to do this on my Tundra for the same reason, but luckily there is enough room on that semi-float setup and an access hole in the backing plate to hammer in studs without removing everything but it was still quite difficult to hammer the new studs in with a punch and mini-sledge. I see no such provision on the LC250. so it;s a major job!
FYI there is a seller on scamazon or fleabay don't remember which, that will make custom hub rings to your specific needs for a reasonable price and they are aluminum or steel. Didn't check into too far as my wheels are hub centric.
One could probably find the post here somewhere as that is where I saw these.
I started reading through all the procedures on TIS, thought of the thread chaser die kit in the garage, and thought, “good enough.” Thank you for the detailed info, educational and confirmed my change in approach. No plan survives first contact!
