Method +35 Photo Request
Well, I'm going to post them anyway even though I'm not using Method +35 wheels. I'm using TRD OffRoad +55 offset wheels with 34x10.5R17 tires in D load. 55 lbs.
Not Method and not 17 but Raceline 18" +35 with Falken 285/70/18 effectively 34" so doesn't fit the spare.
708 with 40 offset on beadgrips
On a 2025/1958 - Stock suspension - No rub.
Wheels:
  • Method MR703
  • 17 inch diameter
  • +35mm offset
TIres:
  • Toyo Open Country ATIII
  • 285/75/R17
  • 6x5.5 (139.5mm)
  • C load rating
Wheels:
  • Method MR703
  • 17 inch diameter
  • +35mm offset
TIres:
  • 285/75/R17
  • 6x5.5 (139.5mm)
  • C load rating
You may have saved me a ton of research! Going for this exact look and set up. Does the spare fit as well? Thanks!
I have the stock tire as the spare right now but I’ve seen others with the same tire and rim are fitting.
The 275/70/18 tires are barely a 1/2 inch thinner and slightly larger diameter and that’s not been an issue fitting. I carry a tire patch kit and air compressor so I don’t worry much about flat tires. I’ve plugged tires many times.
Wheels:
  • Method MR703
  • 17 inch diameter
  • +35mm offset
TIres:
  • 285/75/R17
  • 6x5.5 (139.5mm)
  • C load rating
This is the exact look I'm after. Just wich our 1958's had the thicker fender flares.
How has life been the last three months with the Ridge Grapplers? Any rub going on with the stock set up yet? Thinking about pulling the trigger on Nitto Ridger Grapplers in 285/70R17 with the Method 703s. Really want the spare to fit underneath. Thanks!
Life has been pretty good. No rub at all for daily driving even at full lock which I was a bit shocked. Just drove it down from OR to CA this past week and logged over 1k miles with no problems. Will be hitting Lake Tahoe next week so we will see how it goes. I'm still planning to throw Icons or Kings but just have not found the time to choose and do it.
Wheels:
  • Method MR703
  • 17 inch diameter
  • +35mm offset
TIres:
  • 285/75/R17
  • 6x5.5 (139.5mm)
  • C load rating
Same wheels and stock suspension with different tires for anyone wondering how it would look
BFGoodrich KO3
265/70R17
D load rating
Happy to sling a deal on those Method 703s! PM for deets.
I really like these! I assume they are the Gloss Titanium color? If you had the OEM 18s before, how does the color on the Methods compare? Are they a lot lighter?
Wheels:
  • Method MR703
  • 17 inch diameter
  • +35mm offset
TIres:
  • 285/75/R17
  • 6x5.5 (139.5mm)
  • C load rating
How is the ride on them C rated tires does it still ride smooth or stiff?
Can’t decide between SL or C tires
Do you have photos of how that "spare" (285/70R17) looks in the spare location?
I took it off roading quite a bit so far, and it hasn't been an issue once. The only sounds I hear are the mudflaps and exhaust pipe scraping rock.
I’ve had Nitto Ridge grapplers SL and they were a bit smoother than these on bumpy roads. If you’re not off roading and airing down I’d say get the SL.
Reactions: CFC
