Low range driving
I’m surprised more folks aren’t bothered by this issue. When moving down a trail I don’t want to be screaming the engine away at 4k rpm. Why would Toyota limit this transmission to 4th in low and only then at unreasonably high engine speeds? I’ve never had another automatic 4WD rig programmed this way before, even other Toyotas. I for one don’t like it.
I’ve had good luck manually shifting in manual mode when in 4 lo. Have never experienced a situation so far when I wanted to be in 5th gear but 4 lo.
I tried that too. Wouldn’t let me manually shift until around ~3,500 rpm. I’d be happier being limited to 4th if I could get there at 1,800 or so.
What’s your scenario where you want to be in 4 lo, low RPMs, and 4th gear? Having trouble imaging so I’m intrigued. Every scenario I can think of would be better in 4 hi.
Wherever I'm off-roading, it's fairly common that the terrain will frequently switch between 4LO and "cruising in 4H" situations. Think about short rocky steep uphills that lead to flat areas that lead to more steep rocky uphills.
The transmission should be configured to allow me to be in 4LO where needed for slow torque, then manually shift to 4th or 5th to cruise through those flat areas a bit faster without having to bounce between 4HI and 4LO, since that requires a stop and neutral shift.
If we had a manual transmission, this wouldn't even be a conversation. Unfortunately, the automatic transmission is locking us into whatever bullshit curve Toyota thinks is correct.
This would be fine if I had any confidence that anyone at Toyota ever went out doors for more than a smoke break.
Yep, exactly that. I believe the Grenadier allows the driver all gears in low range. We get 1/2 of ours and I’m puzzled why only a few seem bothered by this predicament.
Transmission overheats otherwise, at least been my experience.
Short range in my car (European version) in low range need rev up to 3500 rpm to go from first gear to second. If you push more, 4th gear come in. In manual mode car change first 3 gears without big problem. To go 4th and even 5th need rev up engine much more. Anyway we buy car with 8 gears and low range. I understand maybe short range need more close gears, not possible but maybe shorter gears more interesting. When drive in track with some hard parts between good fast parts you can go kind of fast without need change from low to high range. I have asked for this to Toyota Spain three weeks ago . Currently I have no answer.
I have had also a problem of vibrations on the steering wheel very unpleasant. Toyota dealer simply says this is due to engine power, a stupid answer. I have made some measures with an accelerometer and I have made a report for Toyota. Yesterday I discovered That the steering wheel was full backwards. Moving some millimeters forward, the problem seems to have reduced very much
