💵 For Sale Looking to sell WESTCOT Lift kit with tires
trailrun641
7
IOWA
2025 Landcruiser
Just bought 2025 Landcruiser from a dealer - they had installed Westcot lift kit and Toyo ( 295 70R 18 tires ) for a customer who backed out of sale, and after driving for a few hundred miles - would prefer no lift and just standard 265mm tires. So looking for either a swap or sale of some kind of my lift kit and tires for tires or $$. I live in Iowa .
Andy
Andy
Are you on stock wheels? Or aftermarket?
Curios of what you don’t like about Westcot lift kit and tire setup?
Just too high, I have a 2022 4Runner that I just added wider tires and really like the look and feel compared to the extra height with Landcruiser.
I got into Landcruiser for 52k , so figured I would try the lift and could be removed easily because they are just spacers and not a true lift system.
What did you want for the lift kit? I'm assuming this is the spacer lift...
Yes, this is just the standard front and rear spacer kit, installed by Toyota dealership. Not sure how much I would need for the kit, would have to figure out what it would cost to remove ? Any ideas ?
If you're not removing them yourself, shop rates can get expensive. This can be compounded if they didn't give you the lower OEM spring perches for the front shocks (that were replaced by the Wescott kit). You might want to find someone to simply swap suspension with you to make the transaction slightly more plug-n-play.
