Lock Lock Hold- remote start without the subscription
Glad you figured out, especially for your wife’s sake! It’s not just a luxury for her like it is for most of us.
Do you think it could be reasonably modified to transmit the signal at higher power, potentially even switchable? Might be a fun collab project with @DubDub, I think he’s an RF guy.
The RFID signal out of a remote is a whisper. Running off of a button battery, there isn’t a great fix that doesn’t mimic what car thieves use. The real solution is to modify the receiver in the vehicle itself. I’m sure it can be done, and I’m sure it has been done. Warranties being warranties… I’m not modifying my ignition path.
While I know a little about transmitters, I'm more versed in how to attenuate them (former career) I believe the length of the antenna and power output have a direct effect on the range. I'm not sure if the FOB does a handshake with the LC security module.
So if it's the antenna length that's doing the attenuation, is it possible to tune the antenna to better match the frequency. That wouldn't be an easy task and would require a precision freq meter. But probably not a low/hi power switch without a redesign of the entire circuit. Probably have a better chance at pairing an older FOB if one could determine the correct board that would be recognized by the LC. I say that because I have a credit card key from a 2020 Tacoma paired to my LC, so it may be possible to add a 2020 Tacoma FOB to the LC. That being said, I highly recommend it be attempted at a dealer who's willing to try, as it may result in the LC becoming "bricked" and they would probably be the only ones that could "unbrick" it
I recall your experience getting the card key working and how even the dealer was unsure!
I agree, but would still tackle it from the receiving station. VHF attenuators are easier than some of the lower freq bands, and a freq meter would give an idea of the required pole length. It would be relatively simple from there to build a static antenna on your home. However, as you mentioned, I don’t know if the fobs freq hop. I suspect they probably just roll the code with an encrypted signal. I’m not carrying a quarter length or half length VHF antenna around, and things get even more precise (and fragile) when you start playing with micro harmonic lengths. I don’t recall the lower VHF lengths to freqs, I was primarily an HF, UHF and SHF/EHF guy.
However, if I could better attenuate onboard the LC I could have a permanent range solution. Just a +3dB increase would effectively double the range of that whisper signal. 6dB would would quadruple it, and 9dB would have you starting your LC from the other end of a football field. VHF LOS is only restricted by horizon, so 12 miles on ground is theoretically a possibility!
This whole conversation got me thinking about my days aloft replacing and inspecting VHF antennas. I thought it was lost to time, but I found it. Here’s me over a decade ago working on receive antennas out on the yardarms.
I have no words…
Thank you for your service.
Try holding a flat metal plate on the opposite side of the fob, so that you are reflecting the radio signal towards the vehicle. Ideally it should be a 1/4 of the wavelength or larger, so at a typical fob frequency of 315Mhz it should be 24cm or larger. Maybe a large metal frying pan or pot?
Tune the TACAN while you’re up there!
Dub - Thanks for your service.
“There are workers aloft” instantly played in my head when I saw it, as if the 1MC was transmitting into my brain!
“Aloft, aloft. There are personnel working aloft onboard (USS ship). Do not rotate or radiate…”
