Lift Gate "Close and Lock" button seems to randomly refuse to close
sideshow06
Bay Area, CA
2027 Land Cruiser
This is a relatively minor thing in the big picture, but annoying since I can't figure out why. I'm curious if anyone has had this experience and/or can explain what's going on.
I have a power lift gate, and it has two buttons. One to simply close the lift gate, like most Toyotas, and a second that closes and locks the lift gate (which is a handy little improvement - my first Toyota with that feature). The weird thing is that sometimes that second button works fine, and other times it double-beeps and refuses to close - indicating something is wrong. But I can't seem to figure out what causes it to do that. It doesn't seem to be a safety feature refusing to close due to me being in the way (stepping back doesn't make it less likely to close). It also doesn't seem to be due to the key fob not being close enough. It's not a matter of the fob being inside the car, or the car still being on. And it never does this with the button that closes without locking. I would say it does this roughly 50% of the time, but at this point it seems random.
Anyone know what I'm missing or doing to cause it not to close?
I noticed the same and from what I can tell it has to do with the location of the key. With the key in my pocket, if I stand too close it won't work (I assume it thinks the key is in the trunk) and if I stand too far back or too far to one side it won't close (I assume the key is too far for the LC to "see" it).
I started making sure that they key is a foot or two off the bumper and roughly centered (inside the red circle more or less) when I hit the button and I've never had an issue since.
My experience is almost the same. Kind of annoying that there's a pretty small "sweet spot". I understand not wanting to lock the car with the key inside, so I appreciate that error. I also understand why you need a key to open it (duh). But I'm not sure why it cares if I have a key or not when I want to lock it.🤷‍♂️
Yea, I absolutely understand not wanting to lock the key in the car, but it seems like there should be more leeway having the key near the trunk. Also, as you said, who cares if I don't have a key on me when I'm locking the vehicle. I feel like it should really only check to make sure the key isn't in the car.
I have found that pushing the lock button and stepping to the left (Drivers Side) makes it work 99% of the time. Every now and then it is finicky and I don't know what the difference is but a second try normally works.
