🛠️ Member Build LC250 Soft close doors
Member Build
GilK
israel
LC250h
purchased directly from Ruiyyco and installed domestically
  • IMG_8218.MOV
    5.7 MB
Reactions: Jon
Very interesting. What does this actually do for you? Is it so you don’t have to fully close the door?
probably making sure that wife does not findout if he was out and about without permission 😜
This was the exact moment that installation of soft close doors became the LC forum’s signaling equivalent to having a joint FB account :ROFLMAO:
how hard was the install? Did you only do the 2 front doors?
The installation for the four doors took several hours; while the door panels were removed, I also installed partial soundproofing in the doors and added foam set by Beat Sonic around the speakers.
2 kits
You mentioned it took several hours to install the kits, but was it straightforward install? How difficult?
This is not “plug and play” installment, you need to use part of the OEM locker parts with the new set
Just call me a grumpy old man…nope this not for me. I just could not trust that to keep a door closed or for it to open in an emergency. Honestly it’s probably fine but my OCD and the grumpy old guy that doesn’t believe in some of the latest tech would drive me nuts… (AKA) I have a 1958…:) and it has more tech than I need.
I've had it on BMW's in the past, and while it is kind of slick, I wouldn't intentionally order the option.
Every time you have a passenger get in or out of the vehicle you have to tell them not to slam the door as they are auto closing doors. And they typically don't understand....
Latest Discussions
