JBL AUDIO UPGRADE — GOING BEYOND THE BEAT-SONIC
Woody
Wa State
2024 LandCruiser 1st edition
2024 LAND CRUISER JBL AUDIO UPGRADE — GOING BEYOND THE BEAT-SONIC
For anyone looking for more volume from the JBL system in a 2024 Toyota Land Cruiser, here’s how I added an amp on my First Edition while keeping the factory Toyota radio.
I started by adding the Beat-Sonic ENA-3T3, which definitely made the factory JBL system louder. I still wanted more, so I installed the Trail Grid Pro Alpine 13-speaker upgrade. The Alpines sounded clear, but the factory JBL amplifier—even with the Beat-Sonic—wasn’t giving me the volume I wanted.
That led me to add a Rockford Fosgate T1000X5ad five-channel amplifier.
I found the PAC APH-TY02 speaker harness online, but information was mixed on whether it would work with the 2024 Land Cruiser’s JBL system. I decided to buy it and try it. Using information from a few different sources, I started identifying which factory amplifier leads went to which speakers. I then used a sound generator to test the individual speaker-side wire pairs and labeled the harness positions as I identified which speakers played. That’s how I worked out the mapping below.
EQUIPMENT USED
• Trail Grid Pro Alpine 13-speaker plug-and-play package
• Beat-Sonic ENA-3T3 and ACS-T02
• PAC APH-TY02 speaker harness
• Rockford Fosgate T1000X5ad five-channel amplifier
• Two JL Audio 10TW3-D4 subwoofers
• Zenclosures dual sealed, down-firing enclosure with fiberfill
• 4-gauge power wiring
• Sound-deadening material
WHY I CHOSE THE ROCKFORD
I chose the T1000X5ad for its compact size, efficient Class AD speaker channels and Class BD subwoofer channel. It provides 100 watts RMS per main channel and 600 watts RMS from the subwoofer channel at 1 or 2 ohms.
I wanted to power the cabin speakers and both subs with one compact five-channel amp, keeping the installation simple and avoiding multiple aftermarket amplifiers. Electrical demand on the Land Cruiser’s hybrid system was a consideration, although actual demand depends on output power, listening volume and amplifier efficiency.
The Rockford also fits in the flip-up storage compartment behind the rear seats, keeping it tucked away without taking up the main cargo floor. For power, I ran 4-gauge wire directly to the battery in the driver-side cargo area.
WHY I ADDED THE ACS-T02
With the ENA-3T3’s standard harness, the RCA preamp output doesn’t follow the factory radio’s volume control. An aftermarket amplifier connected to it therefore won’t turn up and down with the rest of the system.
Beat-Sonic developed the ACS-T02 to solve that problem. It replaces the standard ENA harness and provides a new set of RCA preamp outputs that follow the factory volume knob and steering-wheel volume buttons. It also provides a remote turn-on wire if your aftermarket amplifier needs one. I used the ACS-T02 outputs to supply the audio signal to my Rockford.
At the time of writing, Beat-Sonic is also accepting preorders for the Encore Boost, which combines the factory-amp signal boost and volume-controlled RCA outputs in one unit. The version listed for the 2024 Land Cruiser JBL is the E7T3. My installation uses the separate ENA-3T3 and ACS-T02.
DISABLING ANC AND ENGINE SOUND ENHANCEMENT
I used the Carista app to disable Active Noise Cancellation (ANC) and Engine Sound Enhancement (ESE), turning off the factory noise-canceling function and artificial engine sound through the speakers.
SOUND DEADENING
I applied sound-deadening material in several spots inside the doors and throughout the entire rear hatch to help reduce vibration and rattles.
HOW THE PAC APH-TY02 HARNESS WORKS
The APH-TY02 connects at the factory JBL amplifier under the driver’s seat. It gives you access to the speaker circuits there, allowing you to use the vehicle’s existing speaker wiring without running new wires into every door.
Each speaker circuit has an amplifier-side pair and a speaker-side pair:
• For speakers staying on the JBL amp, connect the matching amplifier-side and speaker-side wires together on the adapter. The JBL amp continues powering those speakers.
• For speakers moving to the Rockford, leave the JBL amplifier-side wires disconnected and individually insulated. Connect the Rockford’s speaker outputs to the adapter’s speaker-side wires. Those wires carry the amplified sound through the existing vehicle wiring to the speakers.
The Rockford’s speaker output does not go through the JBL amplifier. Each speaker group is powered by one amplifier or the other.
WHAT I LEFT CONNECTED TO THE JBL AMP
The center dash speaker at APH-TY02 position 4 remains powered by the factory JBL amp.
Positions 1, 2 and 3 also remain connected because I haven’t confirmed where they go. I left them connected since they didn’t appear to affect the rest of the sound or interfere with the upgrade.
Positions 1 and 2 may be associated with ANC or Engine Sound Enhancement, but I haven’t verified that. I also suspect one of positions 1–3 feeds the factory subwoofer. I had already disconnected that subwoofer before installing the harness, so I couldn’t verify which position feeds it.
APH-TY02 SPEAKER MAPPING
These are the numbered speaker positions on the harness:
1 — Unknown; retained on JBL amp
2 — Unknown; retained on JBL amp
3 — Unknown; retained on JBL amp
4 — Center dash; retained on JBL amp
5 — Driver dash
6 — Passenger dash
7 — Driver hatch
8 — Passenger hatch
9 — Driver front door and A-pillar tweeter
10 — Passenger front door and A-pillar tweeter
11 — Driver rear door and rear-door tweeter
12 — Passenger rear door and rear-door tweeter
The A-pillar tweeters already share the front-door speaker circuits through the factory wiring. The wiring goes to the A-pillar tweeter connection and then continues to the front door. I didn’t make separate A-pillar connections at the APH-TY02.
The rear-door tweeters likewise run through their respective door-speaker circuits.
HOW I GROUPED THE SPEAKERS ON THE ROCKFORD
I grouped the speakers onto the Rockford’s four main channels so the fifth channel could power both subs.
At the speaker-side leads coming off the APH-TY02, I combined these positions, matching positive to positive and negative to negative:
• FRONT LEFT: 5 + 9
Driver dash, front door and A-pillar tweeter.
• FRONT RIGHT: 6 + 10
Passenger dash, front door and A-pillar tweeter.
• REAR LEFT: 7 + 11
Driver rear door, rear-door tweeter and hatch speaker.
• REAR RIGHT: 8 + 12
Passenger rear door, rear-door tweeter and hatch speaker.
• SUBWOOFER CHANNEL:
Both JL Audio subs through separate subwoofer wiring. The factory JBL subwoofer remains disconnected.
TWEETER CROSSOVERS AND SPEAKER LOAD
The Alpine package includes inline crossovers for the tweeters, which filter out the low frequencies before they reach them. Those crossovers remain in place.
Combining speaker circuits changes the load seen by the amplifier. The Rockford supports a minimum of 2 ohms on its four main speaker channels and 1 ohm on its dedicated subwoofer channel. I haven’t verified the combined front-channel impedance, so check your speaker and crossover loads against your amplifier’s ratings before copying these pairings.
SUBWOOFER ENCLOSURE AND WIRING
The two JL Audio 10TW3-D4 subs are installed in a Zenclosures dual sealed, down-firing enclosure. I also added polyester fiberfill inside the enclosure.
Each sub has two 4-ohm voice coils. I wired the two coils on each sub in parallel, making each sub a 2-ohm load. I then wired the two subs in parallel to the Rockford’s subwoofer channel, giving a combined 1-ohm load.
That wiring lets these two dual-4-ohm subs use the Rockford’s full rated 600 watts RMS from its subwoofer channel, shared equally—approximately 300 watts per sub at rated output. The Rockford also produces 600 watts at 2 ohms, but wiring these particular subs with all four voice coils in parallel gives the supported 1-ohm load.
CROSSOVER AND AMP SETTINGS
• Front channels: High-pass, approximately 80 Hz
• Rear channels: High-pass, approximately 80 Hz
• Subwoofer channel: Low-pass, approximately 80 Hz
Amp load settings can be seen in the picture.
This is my installed setup. It's loud, very loud, and very clear. Theres room to turn the amp up more, but it sounds great where it's at.
All factory options remain in use including emergency calling and things like cross trafic audible warnings.
Hope his helps those of you that have wanted more out of ths system but haven't been able to figure out the JBL amp.
