Interesting OEM Discovery Behind the Center Console (2025 LC 1958)
Sorry for the delay, I wanted to double-check the Toyota documentation before posting the part numbers.
The male connector housing that plugs into the factory connector is:
Toyota P/N 90980-12551
For anyone wanting to build the breakout using Toyota OEM components, Toyota also offers the corresponding terminal already attached to a repair wire:
Toyota P/N 82998-24230
The Toyota documentation identifies it as a 0.64 non-waterproof male terminal.
Since the repair wire comes with the terminal already crimped, you do not need a terminal crimping tool if you go that route. You would simply need to properly connect/terminate the repair-wire leads for your application.
For the 4-signal breakout shown in my original post, the available circuits I verified are:
• BATT+
• IG/ACC
• ILL+
• GND
Hope that helps anyone wanting to put one together.
One additional tip for anyone sourcing Toyota OEM parts:
I’ve had good luck using Amayama for genuine Toyota parts from Japan. Their pricing on some of these small connector components can sometimes be considerably better than buying them through a US Toyota dealer.
Amayama — Genuine Toyota Parts from Japan⁠
Just enter the Toyota part numbers directly into their search:
90980-12551 — male connector housing
82998-24230 — repair wire with terminal
Shipping from Japan obviously needs to be factored in, so it usually makes more sense if you’re ordering several parts at the same time.
Just thought I’d mention it since these small Toyota electrical components can get surprisingly expensive through US sources.
