Horn
Did you have trouble installing? I got these and the driver side electrical connection was too short
To move the electrical connection closer to where the plug would reach, I only needed to loosen the horn’s mounting nut on the bolt, which enabled me to swivel the mount on the new horn. That horn’s nut and screw are fairly tight though.
I did the same. Using the driveway floor as leverage got it loose :) then retightened at 90 degrees so the line could reach. I've heard others just rotate the horn completely but then it's touching the radiator and I wasn't comfortable with that.
