Emergency Stop From the Passenger’s Seat
Thank you! Considering we had our trailer in tow, I admit I considered it at the time but was unsure if it would send the vehicle into a situation that I couldn’t steer out of from the passenger seat.
Glad y'all are okay!
@Below32, I just tested it in my 2025 TJH250L-GNZAZA and confirmed it works. Probably on other variants as well, but others would need to confirm. You certainly don’t need to shift into park first, which would defeat the very premise of the idea. The vehicle beeps and fairly rapidly decelerates to a stop.
When you engage the parking brake while moving, do the front brakes engage or just the rears?
Unsure. You should test it and let us know!
I can make an educated guess that the anewer is no. There’s no e-brake hardware on the front brakes. The manuals for others also warn to be careful in that it might be a bit unstable (because they only work on the rears that doing so on a corner can be a bit dangerous in some circumstances). It really is to be done only in the case of an emergency.
If it's rear wheels only my e-turns are going to become a lot more fun.
Found an empty parking lot this morning to try this. It feels like all brakes engage as if you just stomped on the breaks. Not sure I would want to do that at full speed especially with a trailer in tow. However, if one pops the switch up then lets it back down fairly quickly it can act as a light pump of the brakes. Glad I tried it to see how it reacted and tried it as a quick pull & release. It is good info to have should it ever be needed. Winter ice and snow would make this even more interesting but a very reasonable experiment. I am a huge proponent of finding out how ones rig will react in a safe environment vs in the middle of an emergency. Will try the e-brake in a parking lot again when the trailer is attached. Curious to know if it transfers through the 7 pin.
You are smart. I encourage every owner to test to find the limits of their vehicle in a controlled environment.
Fronts are "engaging" because of the center differential. Cant be good for it.
The torsen center differential locks because of the difference in speed between front and rear driveshafts. This of course leads to the front wheel(s) to almost instantly slow to match speed of rears, and at that point it will begin to unlock before locking again.
Assuming you're moving straight forward and there's no wheel slippage would there be any difference in speed between front and rear?
In snow, ice, and maybe rain I'm sure there could be and that would certainly stress the center diff.
I'll try this out someday but wouldn't experiment if traction is compromised.
I believe you're exactly right in that scenario. My experience with this is in subaru sti and audi quattro, mostly on dirt and gravel. STI has an adjustable clutch on the center diff to adjust slippage for (among other uses) using rear hand brake lever briefly to slide rear around without locking fronts. But that"s with the rears actually locked intentionally and clutch depressed on sti. The audi essentially locks the fronts.
I dont know how the rears will behave on LC with handbrake on dry pavement, and depending on available grip and tires etc., behavior could vary greatly as you say. It's something i want to actually try, but not in my own LC.
It's quite complicated trying to determine outcome of this theoretically with torsen torque split and auto trans, and k0, plus rapidly varying friction. Out of my depth for sure with very limited knowledge of LC design.
I'll try it out! As others have said it will be a good thing to know how it will react. Hopefully not like the old e-brakes that never worked in older toyotas, nor like others that locked up just the rears(unless you were intentionally trying to bring the rear end around).
I tested this out on a loose gravel road so I could try to see which wheels were doing the braking.
Also had traction control off (car with swervy lines button).
Stopping hard with the brake pedal all four tires skidded in the gravel.
Using the park brake stopped the Cruiser possibly faster than using the brake pedal, but no skidding.
Probably like @MSINAL said, the front tires are helping also but not being braked with the front brakes, just the front axle being slowed through the drivetrain/center diff.
It was weird that using the park brake was more of a anti-lock feel than the pedal.
Also, after stopping the Cruiser with the park brake, the park brake was set and had to be turned off manually or by putting the truck into park and then drive again.
I was also surprised by how rapidly it decelerated. Seems they really considered the emergency use case.
Going out with the trailer for Memorial Day. Will try this in a parking lot. I am curious if the emergency brake transfers through the 7 pin / brake controller.
You should take your trailer out for Labor Day and test it so we don't have to wait so long. ;)
I tried this today on the street. Best emergency brakes I have ever used!
When you pull up on the switch it starts off as medium power 4 wheel braking for a split second until going to full power 4 wheel braking.
