Those are the specs for the 200.
Nominal caster for the 250 LC LC Premium is 4.22 degrees, so you're good. I don't know what model 250 you have, but they don't vary much.
I just put on OME UCAs and they added a bunch of caster. At first I had almost 6 degrees and I felt a loss of steering range and it felt weird when it hit the stops. I aligned it and got back to right at 4.2 degress on both sides and it feels good now and the steering isn't so heavy anymore.
I still think the lift would make the steering stops hit higher in the Vs of the knuckle, but I can't explain why
@Bad1975 seem to be centered.
This isn't the case for
@solagbmw, but maybe if you have too much or too little caster, the steering axis may be tipped far enough forward or back that only the front or rear stop would hit the V early and that wouldn't feel like a solid stop and would reduce range.
I'm not sure. I'll have to look at mine again, but I know they're hitting high in the Vs even though they feel good now.
Seeing stock stops would be nice to add to the info here.
Specs for 250 caster and camber LC LC Premiun is the RCCA spec:
