Chevron Techron spill…
ultane
⭐ Supporting Member
Cherokee County, NC
First Edition
After my most recent oil and filter change, I put the bottle of Techron in the back seat so I could add it at the next fill up. Two days later, I got into MIss Daisy to drive 110 miles to see my grandson play soccer.
When I got in Miss Daisy, I immediately noticed a faint petrol type smell. I didn’t think anything of it until 3+ hours later when two of my grandkids were getting into the backseat. I went to move the Techron container, and noticed that the container was moist on the outside. So was the leather (perforated) seat!!! 🤬 The bottle was half empty..
I wiped it up with clean paper towels, as best I could.
Does anyone have any suggestions on how to get this stuff out of the foam? Or should I just buy new foam for that seat?
I’ve
I’ve had similar situations, albeit not with any petroleum product. I have had to deal with spoiled milk and dog urine (my old GSD was actively dying and I was taking her back home to my parents to see them one last time).
In my experience, the only way to even come close to removing the contaminant is to flood the seat with a cleaning solvent and lots of water. Saturate it and pull it with a strong vac. Rinse and repeat until the fluids you are pulling are clear and not filmy to the touch. Petroleum would be difficult as it is not soluble with water, but that may assist in raising it to the surface for removal.
Younger me tackled this heavily, and I recall the milk taking weeks of repeat treatments with periods of aeration. Definitely remove the seat and don’t try to do it in the LC. Today me would be simply purchasing a new seat or having an upholstery shop do a pad/cover replacement.
That sucks, bro! But wouldn’t the petroleum-based stuff eventually evaporate over time? Or does it leave something behind in the foam?
Use dawn dish soap. Take that seat cushion out, take the cover off and soak straight dawn into the foam. Let that sit for a bit and then massage the foam and then rinse out with warm water. May take a few treatments, repeat until no product smell remains. Any solvents will eat the foam.
I've haven't done this but it's what I'd try before getting a new foam piece. Do the same with the leather only wipe the dawn into the leather and thin wipe it out with a warm moist water soaked rag and then treat with Lexol leather cleaner and Lexol leather conditioner before the leather can dry from the water in it and repeat the Lexol treatment again after it air dries. Be gentle on the leather no stretching or wringing it when cleaning or it will be stretched out permanently when done.
Of course, you may want to do a spot treatment on an area you can't see first to see if the dawn cleaning and rinsing on the leather followed by the leather treatment will discolor it or not.
I would price a new seat cushion and cover, or used ones from salvage etc. before tackling cleaning yours -which may not end in success. What is your time worth to you? You might have recourse with the place that sold you the leaking bottle as well.
Shop Vac or car wash (if your adventurous) and as mentioned above Dawn power wash dish soap. I'd spray the dawn pwr wash liberally on the seat cushion let it set for a few minutes then suck it dry with the vac. Reapply the dawn and massage the liquid gently into the seat for a few moments, then suck dry. Reapply the dawn and heavily massage and suck dry, repeat several times then switch to plain water and vac a few times. plug in a trickle charger and open all the doors and let air dry, which may take a few days..
The intent is to not force the chemical deeper into the foam while you try and remove it. I've used the dawn power wash on a few nasty spills (not Techron) and it works great.
Call Chevron.get SDS sheet...they may be able to guide you to best solvent. Hate to say it but take that pretty seriously. Those chemicals are hardcore.
A similar techron spill happened in the back cargo area my 80 series, Nothing got rid of it...
eventually i removed the cargo area carpet, took it to my local car detailer
car detailer worked his magic and was successful
I personally would replace the foam cushion and seat skin :(
Copy from gas removal guide on leather seats...
How to Remove Gasoline from Car Seat (Leather)​
Medium20–30 minutes5 steps
Reviewed July 21, 2026
Car Seat (Leather) surface
Gasoline on leather is a time-sensitive emergency that can cause permanent finish dulling if left to soak. The key to saving the hide is removing the solvent-based fuel before it strips the protective topcoat. You will achieve the best results using a gentle dish soap degreaser and immediate, light blotting.
Share
Gather these first​
6 items
Click an item to find it on Amazon.
As an Amazon Associate we earn from qualifying purchases.
The method​
  1. Step 1:​
    Press a dry paper towel firmly against the spill to pull up as much liquid as possible. Avoid any rubbing motion, as this forces the gasoline deeper into the pores of the leather grain. Blot straight down for at least 60 seconds until no more fuel transfers to the towel.
    Tip. Use multiple fresh paper towels as you work to prevent spreading the stain.
    Careful. Do not scrub, as friction will drive the gasoline into the leather finish.
  2. Step 2:​
    Mix a tiny drop of dish soap in a teaspoon of distilled water. Apply this solution to an inconspicuous area, such as the bottom edge of the seat under the cushion. Wait 5 minutes to ensure the cleaner does not cloud or discolor the finish.
    Tip. Check the cloth used for the test to see if any leather dye transferred.
  3. Step 3:​
    Dampen a clean white cloth with the soap solution and gently wipe the affected area in a circular motion. This acts as a degreaser to lift the fuel residue from the surface. Work for 2 minutes while watching the cloth for signs of lifting grime.
    Tip. Use a soft-bristled toothbrush only if the leather is textured, using very light pressure.
    Careful. Never soak the leather, as excess moisture can lead to stiffening or water spots.
  4. Step 4:​
    Wipe the area with a fresh, slightly damp cloth using only distilled water to remove soap residue. Wipe until the surface feels tacky rather than slippery. Residual soap can attract dirt later if left behind.
    Tip. Air dry the area naturally, away from direct sunlight or car heaters.
    Careful. Heat sets the stain permanently and can crack the leather.
  5. Step 5:​
    Inspect the leather once it is completely dry to see if the gasoline odor or stain remains. If the leather feels dry or tight, apply a high-quality leather conditioner to restore the natural oils. Condition the entire seat panel to ensure an even finish.
    Tip. If the smell of gasoline persists after drying, you may need a specialized leather deodorizer.
Work in order, check the stain before using any heat, and stop if the surface reacts badly.
Not your exact situation?​
Search it in your own words.
Gasoline on Car Seat (Leather)...Find the guide
Get the stain guides that actually work​
New guides and the fixes that surprised us. No spam, unsubscribe in one click.
Join
What not to do​
  • Never apply water before degreasing, as this forces the oil deeper into the fibers. This permanent oil locking makes subsequent removal steps virtually impossible.
  • Do not scrub, as friction will drive the gasoline into the leather finish.
  • Never soak the leather, as excess moisture can lead to stiffening or water spots.
  • Heat sets the stain permanently and can crack the leather.
When to call a professional
Removing Gasoline from Car Seat (Leather) may need expert help if home methods do not work.
Simple soaps often leave a hazy residue behind when dealing with heavy gear oils. You must use a stronger solvent-based degreaser to dissolve the remaining synthetic binders that standard detergents miss.
Never mix cleaning products. Bleach with ammonia, vinegar or any acid releases toxic gas. Work with a window open, wear gloves for strong cleaners, keep everything away from children and pets, and test on a hidden spot first. The product label always wins over anything written here. If someone is exposed to fumes or a chemical, call Poison Help at 1-800-222-1222 (US, 24 hours) and get fresh air immediately.
Common questions​
Will gasoline leave a permanent mark on leather seats?
Gasoline can cause permanent finish damage because it acts as a solvent that strips the protective coating off the leather. If you catch it immediately, you can often prevent lasting discoloration or texture loss.
Can I remove gasoline after it has dried on the seat?
Once the fuel has dried, it has likely already interacted with the leather's finish. You can attempt to clean it with the methods above, but professional upholstery cleaning is recommended if the stain remains visible.
What is the best way to clean fuel spills off leather?
Using a mild dish soap solution is the safest and most effective method for lifting petroleum-based stains from automotive leather. It breaks down the oil without the harsh effects of industrial solvents.
Are there household alternatives to leather cleaners?
Dish soap is the most reliable household item for this task because it functions as a degreaser. Avoid using vinegar or alcohol, as these can permanently strip the pigment and protective topcoat from the leather.
How do I protect my car seats from future fuel spills?
Regularly applying a high-quality leather conditioner keeps the material supple and adds a barrier that makes spills easier to wipe away. Avoid keeping fuel containers inside the passenger cabin where they can tip or leak.
Why Gasoline stains Car Seat (Leather)​
Gasoline is a complex solvent that is designed to dissolve oils and resins, which makes it particularly aggressive toward the finish on automotive leather. When it contacts your seat, it doesn't just sit on the surface; it begins to break down the natural oils in the hide and the synthetic topcoat that keeps your leather looking new.
Dish soap works here because it is a powerful degreaser. Its chemical structure allows it to bind with the petroleum components in the gasoline, lifting them away from the leather fibers so they can be wiped off with a cloth. This process is far safer than using solvents like rubbing alcohol, which would simply strip the leather's dye along with the gasoline.
Avoid the temptation to use heat or harsh scrubbing to speed up the process. Heat will cause the leather to lose its natural moisture, leading to cracking, while aggressive scrubbing will physically damage the grain of the leather. If you see the finish appearing cloudy or dull after cleaning, you have likely removed some of the protective topcoat.
Keep your leather conditioned to maintain its resistance to future spills. Leather acts like skin; when it is hydrated and healthy, it is naturally more resistant to absorbing liquids. If you frequently transport fuel, consider using a protective tray or mat to provide an extra layer of defense between the container and your upholstery.
Why this method fits this combination​
  • Mechanical fluids contain complex petroleum bases that penetrate deep into fabrics through capillary action. If you allow these liquids to settle, they clog the weave and trap dirt, making extraction significantly harder.
  • Most car seats rely on a protective topcoat that holds liquid on the surface long enough for you to blot it away. Once a stain reaches the stitching or the foam padding underneath, moisture gets trapped and can mildew or leave a ring you never fully lift.
  • Simple soaps often leave a hazy residue behind when dealing with heavy gear oils. You must use a stronger solvent-based degreaser to dissolve the remaining synthetic binders that standard detergents miss.
  • This method is written specifically for Gasoline on Car Seat (Leather); the protective topcoat keeps most spills sitting on the surface long enough to blot away before they bond with the dye underneath
Written and reviewed by Stain Removal Guides Editorial Team, checked against solvent-safety and surface-integrity rules. Every guide covers a specific stain on a specific surface — not a generic tip adapted from somewhere else. Each method is checked against our chemical-safety rules and the surface’s care flags before publication. No guarantee of results — materials vary, so always spot-test first. Updated July 21, 2026.
Join
Search it in your own words. Everyday words and typos are fine.
Techron is far more of an issue IMHO than gas. Gas volatilizes pretty fast. Techron does not. It takes a lot of heat to ignite it and a reason behind it 'burning off carbon buildup...I believe. Here is the SDS
_____________________________________________________________________
Revision Number: 18
Revision Date: November 05, 2025
1 of 9 Techron Concentrate Plus
SDS : 36726
Safety Data Sheet
SECTION 1 IDENTIFICATION
Recommended Use: Gasoline fuel additive
Restrictions on Use: Consult supplier when used other than those specified.
Other means of identification: Not applicable
Product Number(s): 266701
Company Identification
Chevron Products Company
a division of Chevron U.S.A. Inc.
1400 Smith Street
Houston, TX 77002
United States of America
www.chevronlubricants.com
Transportation Emergency Response
CHEMTREC: (800) 424-9300 or (703) 527-3887
Health Emergency
Chevron Emergency Information Center: Located in the USA. International collect calls accepted. (800)
231-0623 or (510) 231-0623
Product Information
email : lubemsds@chevron.com
Product Information: 1 (800) 582-3835, LUBETEK@chevron.com
SECTION 2 HAZARDS IDENTIFICATION
CLASSIFICATION:
• Flammable liquid: Category 4.
• Aspiration toxicant: Category 1.
Signal Word: Danger
Physical Hazards:
• Combustible liquid.
Health Hazards:
• May be fatal if swallowed and enters airways.
PRECAUTIONARY STATEMENTS:
General:
Revision Number: 18
2 of 9 Techron Concentrate Plus
SDS : 36726
• Keep out of reach of children.
• Read label before use.
Prevention:
• Keep away from open flames and hot surfaces. - No smoking.
• Wear protective gloves, protective clothing, eye protection, and face protection.
Response:
• IF SWALLOWED: Immediately call a POISON CENTER, doctor, or physician.
• Do NOT induce vomiting.
• In case of fire: Use media specified in the SDS to extinguish.
Storage:
• Store in a well-ventilated place.
• Store locked up.
Disposal:
• Dispose of contents and container in accordance with applicable local, regional, national, and
international regulations.
HAZARDS NOT OTHERWISE CLASSIFIED: Not Applicable
SECTION 3 COMPOSITION/ INFORMATION ON INGREDIENTS
COMPONENTS CAS NUMBER AMOUNT
Distillates (petroleum), hydrotreated light 64742-47-8 80 - 85 %weight
01154100-5179P Trade secret 15 - 20 %weight
Dodecane 112-40-3 10 - 15 %weight
Undecane 1120-21-4 5 - 15 %weight
01154100-5323P Trade Secret 0.1 - < 1 %weight
SECTION 4 FIRST AID MEASURES
Description of first aid measures
Eye: No specific first aid measures are required. As a precaution, remove contact lenses, if worn, and
flush eyes with water.
Skin: Wash skin with water immediately and remove contaminated clothing and shoes. Get medical
attention if any symptoms develop. To remove the material from skin, use soap and water. Discard
contaminated clothing and shoes or thoroughly clean before reuse.
Ingestion: If swallowed, get immediate medical attention. Do not induce vomiting. Never give anything
by mouth to an unconscious person.
Inhalation: No specific first aid measures are required. If exposed to excessive levels of material in the
air, move the exposed person to fresh air. Get medical attention if coughing or respiratory discomfort
occurs.
Most important symptoms and effects, both acute and delayed
IMMEDIATE HEALTH EFFECTS
Eye: Not expected to cause prolonged or significant eye irritation.
Skin: Skin contact may cause drying or defatting of the skin. Symptoms may include pain, itching,
discoloration, swelling, and blistering. Contact with the skin is not expected to cause an allergic skin
response. Not expected to be harmful to internal organs if absorbed through the skin.
Ingestion: Highly toxic; may be fatal if swallowed. Because of its low viscosity, this material can directly
enter the lungs, if swallowed, or if subsequently vomited. Once in the lungs it is very difficult to remove
and can cause severe injury or death.
Inhalation: Not expected to be harmful if inhaled.
DELAYED OR OTHER HEALTH EFFECTS: Not classified
Revision Number: 18
3 of 9 Techron Concentrate Plus
SDS : 36726
Indication of any immediate medical attention and special treatment needed
Note to Physicians: Ingestion of this product or subsequent vomiting may result in aspiration of light
hydrocarbon liquid, which may cause pneumonitis.
SECTION 5 FIRE FIGHTING MEASURES
EXTINGUISHING MEDIA: Use water fog, foam, dry chemical or carbon dioxide (CO2) to extinguish
flames.
UNSUITABLE EXTINGUISHING MEDIA: No data available
Unusual Fire Hazards: See Section 7 for proper handling and storage.
PROTECTION OF FIRE FIGHTERS:
Fire Fighting Instructions: This material will burn although it is not easily ignited. For fires involving this
material, do not enter any enclosed or confined fire space without proper protective equipment, including
self-contained breathing apparatus.
Combustion Products: Highly dependent on combustion conditions. A complex mixture of airborne
solids, liquids, and gases including carbon monoxide, carbon dioxide, and unidentified organic
compounds will be evolved when this material undergoes combustion. Combustion may form oxides of:
Nitrogen.
SECTION 6 ACCIDENTAL RELEASE MEASURES
Personal precautions, protective equipment, and emergency procedures: Observe all relevant local
and international regulations. Eliminate all sources of ignition in the vicinity of the spill or released vapor.
If this material is released into the work area, evacuate the area immediately. Monitor area with
combustible gas indicator. Keep out unnecessary and unprotected personnel. Persons entering the
contaminated area to correct the problem or to determine whether it is safe to resume normal activities
must comply with all instructions and wear appropriate personal protective equipment as indicated in
Section 8.
Spill Management: Stop the source of the release if you can do it without risk. Contain release to
prevent further contamination of soil, surface water or groundwater. Clean up spill as soon as possible,
observing precautions in Exposure Controls/Personal Protection. Use appropriate techniques such as
applying non-combustible absorbent materials or pumping. All equipment used when handling the
product must be grounded. A vapor suppressing foam may be used to reduce vapors. Use clean non-
sparking tools to collect absorbed material. Where feasible and appropriate, remove contaminated soil.
Place contaminated materials in disposable containers and dispose of in a manner consistent with
applicable regulations.
Reporting: Report spills to local authorities and/or the U.S. Coast Guard's National Response Center at
(800) 424-8802 as appropriate or required.
SECTION 7 HANDLING AND STORAGE
General Handling Information: Avoid contaminating soil or releasing this material into sewage and
drainage systems and bodies of water.
Precautionary Measures: Liquid evaporates and forms vapor (fumes) which can catch fire and burn with
explosive force. Invisible vapor spreads easily and can be set on fire by many sources such as pilot
lights, welding equipment, and electrical motors and switches.
Storage, processing, handling, and use at temperatures above the flash point can produce ignitable
vapors if the liquid is released or vessels are vented. Do not get in eyes, on skin, or on clothing. Do not
taste or swallow. Wash thoroughly after handling. Keep out of the reach of children.
Static Hazard: Electrostatic charge may accumulate and create a hazardous condition when handling
this material. To minimize this hazard, bonding and grounding may be necessary but may not, by
Revision Number: 18
4 of 9 Techron Concentrate Plus
SDS : 36726
themselves, be sufficient. Review all operations which have the potential of generating and accumulating
an electrostatic charge and/or a flammable atmosphere (including tank and container filling, splash filling,
tank cleaning, sampling, gauging, switch loading, filtering, mixing, agitation, and vacuum truck operations)
and use appropriate mitigating procedures.
Container Warnings: Container is not designed to contain pressure. Do not use pressure to empty
container or it may rupture with explosive force. Empty containers retain product residue (solid, liquid,
and/or vapor) and can be dangerous. Do not pressurize, cut, weld, braze, solder, drill, grind, or expose
such containers to heat, flame, sparks, static electricity, or other sources of ignition. They may explode
and cause injury or death. Empty containers should be completely drained, properly closed, and promptly
returned to a drum reconditioner or disposed of properly.
General Storage Information: DO NOT USE OR STORE near heat, sparks, flames, or hot surfaces .
USE AND STORE ONLY IN WELL VENTILATED AREA. Keep container closed when not in use.
SECTION 8 EXPOSURE CONTROLS/PERSONAL PROTECTION
GENERAL CONSIDERATIONS:
Consider the potential hazards of this material (see Section 2), applicable exposure limits, job activities,
and other substances in the workplace when designing engineering controls and selecting personal
protective equipment (PPE). If engineering controls or work practices are not adequate to prevent
exposure to harmful levels of this material, refer to PPE information below.
Factors that affect PPE include, but are not limited to: properties of the chemical, other chemicals which
may contact the same PPE, physical requirements (fit & sizing, cut/puncture protection, dexterity, thermal
protection, etc.), and potential allergic reactions to the PPE material. It is the responsibility of the user to
read and understand all instructions and limitations supplied with the equipment since protection is
usually provided for a limited time or under certain circumstances. Refer to appropriate CEN standards.
ENGINEERING CONTROLS:
Use in a well-ventilated area.
PERSONAL PROTECTIVE EQUIPMENT
Eye/Face Protection: Wear protective equipment to prevent eye contact. Selection of protective
equipment may include safety glasses, chemical goggles, face shields, or a combination depending on
the work operations conducted.
Skin Protection: Wear chemical personal protective equipment (PPE) to prevent skin contact. Selection
of chemical protective clothing should be performed by an Occupational Hygienist or Safety Professional
and be based upon applicable standards (ASTM F739 or EN 374). Using chemical PPE depends upon
operations conducted and may include chemical gloves, boots, chemical apron, chemical suit, and
complete facial protection. Refer to PPE manufacturers to obtain breakthrough time information to
determine how long PPE can be used before it needs to be replaced. Unless specific glove
manufacturer data indicates otherwise, the below table is based upon available industry data to assist in
the glove selection process and is intended to be used as reference only.
Chemical Glove Material Thickness
(mm)
Typical Breakthrough Time
(minutes)
Nitrile 0.8 5
Nitrile 0.2 15
Polyvinyl Chloride (PVC) 1.1 2
Viton Butyl 0.3 120
Respiratory Protection: Not required for identified conditions of use. A site-specific risk assessment
should be conducted by an Occupational Hygienist or a Safety Professional to determine the type and
Revision Number: 18
5 of 9 Techron Concentrate Plus
SDS : 36726
use of respiratory protective equipment. When a site-specific risk assessment determines that respiratory
protection is required, use an approved respirator such as:
Air purifying respirator -
Vapors only: organic vapor cartridge (filter type A3 per EN 529:2005).
Vapors and particulates (including generated mists): both an organic vapor cartridge & particulate filter
(AP3 filter per EN 529:2005).
Refer to EN 529:2005, USA OSHA 1910.134, and/or other applicable local/regional/national/international
standards for regulatory requirements.
Occupational Exposure Limits:No applicable occupational exposure limits exist for this material or its
components. Consult local authorities for appropriate values.
SECTION 9 PHYSICAL AND CHEMICAL PROPERTIES
Attention: the data below are typical values and do not constitute a specification.
Color: Colorless to yellow
Physical State: Liquid
Odor: Petroleum odor
Odor Threshold: No data available
pH: Not Applicable
Vapor Pressure: No data available
Relative Vapor Density: No data available
Initial Boiling Point: No data available
Solubility: Soluble in hydrocarbons; insoluble in water
Freezing Point: No data available
Melting Point: No data available
Particle Characteristics: Not applicable
Density: 0.8285 kg/l @ 15°C (59°F) (Typical)
Kinematic Viscosity: 9 mm2/s @ 40°C (104°F) (Minimum)
Coefficient of Therm. Expansion / °F: No data available
Evaporation Rate: No data available
Decomposition temperature: No data available
Partition coefficient n-octanol/water (logarithmic value): No data available
FLAMMABLE PROPERTIES:
Flammability (solid, gas): Not Applicable
Flashpoint: (Pensky-Martens Closed Cup) 62 °C (144 °F) (Minimum)
Autoignition: No data available
Flammability (Explosive) Limits (% by volume in air): Lower: Not Applicable Upper: Not
Applicable
SECTION 10 STABILITY AND REACTIVITY
Reactivity: May react with strong acids or strong oxidizing agents, such as chlorates, nitrates,
peroxides, etc.
Chemical Stability: This material is considered stable under normal ambient and anticipated storage
and handling conditions of temperature and pressure.
Possibility of Hazardous Reactions: Hazardous polymerization will not occur. May react with strong
acids or strong oxidizing agents, such as chlorates, nitrates, peroxides, etc.
Revision Number: 18
6 of 9 Techron Concentrate Plus
SDS : 36726
Incompatibility With Other Materials: Not applicable
Hazardous Decomposition Products: None known (None expected)
SECTION 11 TOXICOLOGICAL INFORMATION
Information on toxicological effects
Serious Eye Damage/Irritation: The material is not considered an eye irritant. The product has not been
tested. The statement is based on evaluation of data for similar materials or product components.
Skin Corrosion/Irritation: The material is not considered a skin irritant. The product has not been tested.
Skin Sensitization: The material is not considered a skin sensitizer. The product has not been tested.
Acute Dermal Toxicity: The material is not considered a dermal toxicant. The product has not been
Acute Oral Toxicity: The material is not considered an oral toxicant. The product has not been tested.
Acute Inhalation Toxicity: The material is not considered an inhalation toxicant. The product has not
been tested. The statement is based on evaluation of data for similar materials or product components.
Acute Toxicity Estimate: Not Determined
Germ Cell Mutagenicity: The material is not considered a mutagen. The product has not been tested.
Carcinogenicity: The material is not considered a carcinogen. The product has not been tested. The
Reproductive Toxicity: The material is not considered a reproductive toxicant. The product has not been
Specific Target Organ Toxicity - Single Exposure: The material is not considered a target organ
toxicant (single exposure). The product has not been tested. The statement is based on evaluation of
Specific Target Organ Toxicity - Repeated Exposure: The material is not considered a target organ
toxicant (repeated exposure). The product has not been tested. The statement is based on evaluation of
Aspiration Hazard: This material is considered an aspiration hazard based on the kinematic viscosity of
the material.
SECTION 12 ECOLOGICAL INFORMATION
ECOTOXICITY
This material is not expected to be harmful to aquatic organisms.
The product has not been tested. The statement has been derived from the properties of the individual
components.
MOBILITY
No data available.
Revision Number: 18
7 of 9 Techron Concentrate Plus
SDS : 36726
PERSISTENCE AND DEGRADABILITY
This material is not expected to be readily biodegradable. The product has not been tested. The
statement has been derived from the properties of the individual components.
POTENTIAL TO BIOACCUMULATE
Bioconcentration Factor: No data available.
SECTION 13 DISPOSAL CONSIDERATIONS
Use material for its intended purpose or recycle if possible. This material, if it must be discarded, may
meet the criteria of a hazardous waste as defined by international, country, or local laws and regulations.
SECTION 14 TRANSPORT INFORMATION
The description shown may not apply to all shipping situations. Consult 49CFR, or appropriate
Dangerous Goods Regulations, for additional description requirements (e.g., technical name) and mode-
specific or quantity-specific shipping requirements.
DOT Shipping Description: UN1268, PETROLEUM PRODUCTS, N.O.S., COMBUSTIBLE LIQUID, III;
NON-BULK PACKAGES ARE EXEMPTED FROM THE PROVISIONS OF 49 CFR IN USA
JURISDICTIONS
IMO/IMDG Shipping Description: NOT REGULATED AS DANGEROUS GOODS FOR TRANSPORT
UNDER THE IMDG CODE
ICAO/IATA Shipping Description: NOT REGULATED AS DANGEROUS GOODS FOR TRANSPORT
UNDER ICAO
Transport in bulk according to Annex II of MARPOL 73/78 and the IBC code:
Not applicable
SECTION 15 REGULATORY INFORMATION
EPCRA 311/312 CATEGORIES:
Aspiration Hazard
Flammable (gases, aerosols, liquids, or solids)
REGULATORY LISTS SEARCHED:
01-1=IARC Group 1 05=MA RTK
01-2A=IARC Group 2A 06=NJ RTK
01-2B=IARC Group 2B 07=PA RTK
02=NTP Carcinogen 08-1=TSCA 5(e)
03=EPCRA 313 08-2=TSCA 12(b)
04=CA Proposition 65
The following components of this material are found on the regulatory lists indicated.
Dodecane 08-2
CHEMICAL INVENTORIES:
Revision Number: 18
8 of 9 Techron Concentrate Plus
SDS : 36726
All components comply with the following chemical inventory requirements: AIIC (Australia), DSL
(Canada), ENCS (Japan), TSCA (United States).
One or more components does not comply with the following chemical inventory requirements: IECSC
(China), KECI (Korea), NZIoC (New Zealand), PICCS (Philippines), TCSI (Taiwan).
NEW JERSEY RTK CLASSIFICATION:
Under the New Jersey Right-to-Know Act L. 1983 Chapter 315 N.J.S.A. 34:5A-1 et. seq., the product is to
be identified as follows: Refer to components listed in Section 3.
SECTION 16 OTHER INFORMATION
NFPA RATINGS: Health: 0 Flammability: 2 Reactivity: 0
HMIS RATINGS: Health: 1 Flammability: 2 Reactivity: 0
(0-Least, 1-Slight, 2-Moderate, 3-High, 4-Extreme, PPE:- Personal Protection Equipment Index
recommendation, *- Chronic Effect Indicator). These values are obtained using the guidelines or
published evaluations prepared by the National Fire Protection Association (NFPA) or the American
Coatings Association (ACA) (for HMIS ratings).
REVISION STATEMENT:
SECTION 01 - Company SDS Address information was modified.
SECTION 01 - Health Emergency information was modified.
SECTION 02 - Precautionary Statements information was modified.
SECTION 03 - Composition information was modified.
SECTION 06 - Personal Precautions, Protective Equipment and Emergency Procedures information was
modified.
SECTION 08 - Personal Protective Equipment information was modified.
SECTION 08 - Respiratory Protection information was added.
SECTION 08 - Respiratory Protection information was deleted.
SECTION 08 - Respiratory Protection information was modified.
SECTION 15 - Chemical Inventories information was added.
SECTION 15 - Chemical Inventories information was modified.
SECTION 15 - Regulatory Information information was added.
ABBREVIATIONS THAT MAY HAVE BEEN USED IN THIS DOCUMENT:
TLV - Threshold Limit Value TWA - Time Weighted Average
STEL - Short-term Exposure Limit PEL - Permissible Exposure Limit
GHS - Globally Harmonized System CAS - Chemical Abstract Service Number
ACGIH - American Conference of Governmental
Industrial Hygienists
IMO/IMDG - International Maritime Dangerous Goods
Code
API - American Petroleum Institute SDS - Safety Data Sheet
HMIS - Hazardous Materials Information System NFPA - National Fire Protection Association (USA)
DOT - Department of Transportation (USA) NTP - National Toxicology Program (USA)
IARC - International Agency for Research on
Cancer
OSHA - Occupational Safety and Health Administration
NCEL - New Chemical Exposure Limit EPA - Environmental Protection Agency
SCBA - Self-Contained Breathing Apparatus PNOS - Particles Not Otherwise Specified
Prepared according to the 29 CFR 1910.1200 (2024) by Chevron.
The information in this SDS is based on the knowledge, information, and belief of Chevron and its affiliates
Revision Number: 18
9 of 9 Techron Concentrate Plus
SDS : 36726
as of the publication date. It is not a quality specification, and no warranty, express or implied, is given. We
assume no responsibility or liability for the results of using this material. The information presented here
pertains only to the listed product. Since conditions of use are beyond our control, it is the user's
responsibility to determine the conditions for safe use of this product and assess its suitability for their
application. Users should seek additional guidance if necessary.
Sorry to wreck your day
OP you’ve received lots of good ideas here. So I will offer a bad one.
Bonfire under a full moon. Imagine the Techron-powered flames rising into the air!
Excellent bad idea!
Just the seat cushion or the whole truck? 🔥
Once you get tired of trying to get the petrol smell out.......... get an ozone generator from amazon and use it as many times as needed to eliminate the smell. I have loaned mine out to several people and not one has anything bad to say about the treatment.
Well, I had a quart size spray bottle I bought from Lowe’s, with Dawn and water. I normally use it to clean the Weber when it gets a little dirty.
I started spraying it on the seat, getting it good and wet. Rubbed it well with a couple of those yellow shop rags that I got at Costco. They seemed to absorb some of the Techron, as they began to smell like it. I was also using a shop vac(minus the paper filter). I tossed those two shop rags, and started using white Bounty paper towels to soak up excess soapy water. I noticed that white paper towels had a slight yellow tint to them, from the Techron. I kept spraying, blotting, vacuuming, and more blotting with Bounty paper towels. They seamed to be getting less and less of the yellow colored Techron on them, and eventually none.
The perforated leather smelled much less like Techron, and more like Dawn, when I called it a day. I closed up MIss Daisy, with the four windows cracked about 1/2” to 3/4” to let the car breath some overnight. I also left a smart charger plugged into a type specific pig tail on the battery overnight.
Tomorrow, after doing some honey do things on my GF’s list, I will start again on Miss Daisy. I plan on doing several more rounds of Dawn/water, shop vac, Bounty… Then I will start flushing the seat bottom with water, sprayed on (just like I did with the dawn/water solution) and vacuuming it off the seat as best I can. I have a couple of those “air-mover’s” used to dry floors and carpets, and will set one of those up on the passenger side, blowing across the seat and out the window or door.
If I cannot get all the smell out, I will try @EOD Guy’s ozone generator, but I am not sure if it will do much for Techron. 🤞
Worse case scenario, I will buy another Toyota seat bottom foam piece, and have new katzkin (?) leather installed…. this time Java, instead of black.
I never really considered myself a Luddite, but at 70, I have never really developed my Google-foo skills, like others on here seem to have mastered.
Maybe I will see what I can find out.
If the ozone generator will get out 20 years of a chain smoker smell out of a cloth interior, it'll do well on petro smells...... LOL.
Keep in mind that peoole will sit on the seat at some point. Any remaining moisture could give them a wet bum.
I'd bite the bullet and buy new seat cushion and cover, then take the receipt to the store you bought the techron from. I'm sure they will reimburse you. We had similar issue with some liquid and store didnt even argue, they reimbursed and apologized.
I'm telling you the shampooer, steam cleaner, and shop vac did magic on mine to get the bleach out. But as you can see in the video, I probably went through a gallon of liquid soaking it and vacuuming.
Latest Discussions
