The cutoff switch does not prevent canbus attacks which is the common way to steal the LC. I bought one , it’s useless .
The common way to steal LC250’s is first enter the vehicle without the alarm activating by unlocking via the canbus. Then program a new key via the powered obd2 port. Then start ignition and drive away.
The kill switch doesn’t, and is not positioned as preventing the first two, it just stops the final part, only if you don’t find the switch or associated wiring. Both finding the switch or removing the wiring are designed to be time consuming and not something the average car thief will do. So in the majority of cases it will serve its purpose of preventing the vehicle from being stolen.
To stop opening the vehicle without the alarm going off, you fit an alarm system that says it prevents canbus attacks that can open the vehicle. I’m not sure that one really exists to do this. So 300mods sells an additional alarm that activates on door tampering or vehicle opening.
To prevent programming a new key via the OBD2 port 300 mods sells a OBD2 device that stops power to the OBD2 port unless the ignition is on. To get around this a thief would either have to find the OBD2 device and remove plus rewire. Not hard to do, but probably 20-30 minutes. So sufficient to deter the majority.
Most modern immobilisers like Ghost etc., step in after steps 1 and 2. So even if you’ve silently gained entry to the vehicle, programmed a new key, you still can’t drive away without deactivating the immobiliser. So you’d either need to know the code or remove it. Removing is not impossible, just again requires time and pulling apart dash, removing and rewiring. It’s typically going to take a very knowledgeable thief 30 minutes plus to do this.
So, if you want to give maximum protection to your Land Cruiser, you layer in protection/s. You could opt for an extra alarm to sound on forced entry, OBD2 device to prevent programming a new key. Modern immobiliser like Ghost to prevent it being driven away, and kill switch to do the same.
The effort to overcome all of this is too much/too time consuming for majority of thieves. People always then say, what if they low load it away - that’s a valid question - but how many thieves do this really?
Fixing the canbus attacks only stops the thieves from gaining silent entry. It actually doesn’t take long to program a new key. I suspect if you solved for that, they would just smash a window or sunroof to gain entry and be away in 1-2 minutes.
