BlackStone oil analysis
I use OEM filters, especially during the warranty period, to avoid any possible warranty struggles. Besides, they are extremely reasonable in price. However, I do wish the dealers would have the Japanese manufactured filters, but sadly not.
Glad to see that my first report (638 miles) is in line with what everyone else is getting. Seeing some of the subsequent reports above, I'm thinking sticking with OEM oil filter is more than sufficient. Thoughts?View attachment 57278
I plan to do the next one around 2500, then at 5K, and every 5K thereafter. Or maybe I'll do at 2 K to spread out the progression a bit.
We saw a huge increase in Aluminum @ 3k, 5k, and 10k miles. Showing an abnormal increase in main bearing wear. I would continue to analyze with Blackstone until 20k miles or when the motor is broken in. You have a good baseline test... the metal should remain the same and start to drop with time. Unfortunately mine did not.
Blackstone is excellent resource and they have lots of results for the T24A-FTS, so they can see the trends. Also feel free to call them, I spoke to them directly about my results to confirm what I was seeing was abnormal.
What are you doing about it? Is it a warranty claimable issue or do you have to wait until something fails?
We are exploring all options. Especially given Toyota’s current design and manufacturing issues regarding main bearings and debris left after manufacturing. Not worth the risk long term. If you see high amounts of any metal in the oil after break in it is not good.
The design/manufacturing regarding bearing and debris was for the Tundra, Sequoia and Gx.
As of today that is correct and documented on the V35A-FTS. Some of us are seeing similar issues with the T24A-FTS, time will tell how many are affected.
What we have seen for the T24A-FTS.
1.Full short block replacements offered from the dealership
2.Very high amounts of Aluminum in the oil after break in (the main bearings are Aluminum)
3.Full failure of the T24A-FTS
I used Blackstone for several vehicles, motorcycles, and my Gravely for over ten years, but switched to Lake Speed Jr’s company, SPEEDiagnotics, for all of Miss Daisy’s oil analysis’s. His turn around times are 2-3 days, vs Blackstone’s 2-4 weeks.
1. How many replacements offered?
The LC motor is used in many other vehicles, I think you would see an issue by now if there was manufacturing issues or a design issue.
I don’t really want to get this thread off topic. If you own a T24A-FTS there have been issues since it was launched. If you plan on keeping it long term past the drive line warranty know the issues some of us have had and make your own decisions. The reliability Toyota had 4 years ago is gone until proven otherwise. Also don’t be naive and think Toyota will always do the right thing.
For this oil testing thread -
At a minimum I would test the oil during break in and verify there is not high amounts of any metal in oil. Especially aluminum.
For those wanting more information on the engine issues we have seen since the T24A-FTS was launched please see this thread.
Plus, he is the proud new owner of a Tacoma, the T24A-FTS engine in it, and will be doing his usual excellent work analyzing his Tacoma’s oil during break-in and after, so it may apply to our engines (though I do not believe his Tacoma is hybrid) in that regard.
And 62% more expensive!
Here is my next one. I messed up an forgot to fill the sample bottle on initial drain, so had to barely scrape by from the remaining drips, thus not providing enough sample for a flashpoint test.
Next test will be around 5K, then I think I'll change every 5 and test every 10 thereafter.
Here’s another to add. Quoting the text from their analysis below for my 2025 with 2000 miles on the truck and oil:
“Congrats on the new Land Cruiser! Compared to other T24A-FTS engines, this one is producing a lot more metal and silicon. That's okay, though! This is the initial factory fill, so the extra metal and silicon are normal finds, due to wear-in and harmless assembly sealers. After a few more oil changes, your results should look more like universal averages on the far right, which are specific to this particular model of Toyota after a run of about 4,500 miles. Just check back next time to look for progress. No fuel or coolant contamination was found in the OW/20-grade oil.”
Blackstone labs
Forgot to post my third one.
Asked the dealership on Saturday to take a sample of my oil when they did the 10K Toyota Care service... and of course they didn't take it. This is why I don't trust anyone else touching my car. I guess I'm sticking with my plan of change every 5, test every 10.
These days, you are on your own...
Shame but its up to each of us to guide his own ship. Not much help anymore.
