I really miss surf fishing..Thats all good. Usually after air down pushing the auto button works for my needs. Mainly driving to my surf fishing spot...
This matches what I’ve been experiencing with the vehicle. Mostly keep it in 4Hi with MTS Sand turned on. I was doing some repeated hill climbs up a very large dune Saturday, and I tried a few times without MTS Sand turned on and it wouldn’t get very far up the hill before it was just digging me down to the frame. Sand mode back on and it would climb every time. Tires down to 10 PSI and I was getting fantastic flotation.I never had to go in 4L. All I did was put it in sand mode and all other settings were normal driving settings.
You guys getting all 8 gears in 4LO? Mine is just 1st - 4th.Here is a summary of Pearls I garnered when I got my LC 250 in 2024.
Off Road Pearls
Center diff can be locked/unlocked in 4H and 4L. While moving up to 62mph
4L engaged while stopped and in neutral
Rear locker engaged only when in 4L with center diff locked and stopped. Don't exceed 5mph.
Sway bar disconnect enabled in 4H or 4L , while stopped or in motion, as long as vehicle speed is under 19mph. Center diff can be unlocked or locked. Will automatically reconnect after 19mph.
Tire Pressure
· Hwy / Roads: 30-40 psi
· Gravel / Dirt Roads: 25-30
· Rocky / Muddy Terrain: 20-25
· Muddy / Snow / Sandy: 15-20
· Soft Sand / Mud: 10-15
· Emergency: 5-10
· Speed warning Rule of thumb: % reduction in pressure = % reduction in speed
4LO vs 4HI
4H= 8 gears
4L= 8 high torque gears
4L = more torque, less speed
Firm Surfaces love torque, Loose surfaces hate torque: 4L + Loose surface = Bury the Vehicle
4H = E = mc2 Go fast (momentum) to lose weight: Loose surfaces love speed speed=lightness
2nd Start: 4H/2nd gear for getting out of slippery situations
· Variables: Grade / Angle & Road Surface
· Off Road: steeper angles and different surfaces (firm vs loose)
· 4L for steep and firm
o Good for up hill
o Good for downhill (engine braking)
When to Use Lockers
When traction is low
· Mud, sand, gravelly loose road
o EXCEPT side slope of loose conditions
When to Use Rear Lockers
Diff lockers make up for lack of contact with the road
Up and down hills (4L)
When bogged down
When Not to Use Lockers
· Use ONLY in 4L @ low speed
o If using momentum, no lockers
· High Stress & Load Situations at Speed
· High Traction Surfaces off road
o High Traction Uneven surfaces OK
· Never use front locker downhill
· Never use front locker in full turn
· Never when stuck between a rock and a hard place
PKSB Off
VSC Off
Tire Pressure
· Rule of thumb: Decrease OK to ~ rim size (20 PSI)
· Corrugation: Decrease 20-40%
· Check Tire Temperature Frequently (& Shock temperature)
Sand
· Sand Mode (disable ESC and Trac)
· Low Range
· Diff locks rarely needed
o Lockers good when there is a structure in the sand: drift wood, dirt berm, big rock, scalloped sand, hard-packed sand
· Momentum: throttle control
· Drive in Manual: keep 2300-2500 rev range for reserve if needed
· CRAWL Control preferred: seeks to maintain a constant speed and backfills
A-TRAC
A-TRAC only uses brake pressure. Differential braking to eliminate wheel spin / allow torque of non-spinning wheel(s)
· Acceleration necessary to build torque
· Works at very Low Speed – 4L
o ~ ≤ 5 mph
· Designed to work from Dead Stop
o For starting /accelerating from slippery / poor traction surfaces
MTS
Best used for general off-roading and light and moderate hill climbing and descending.
Mud and Sand selection is the only function that can operate in 4H and 4L. All other selection can operate in 4L only.
MTS uses both brake pressure and throttle.
MTS will allow different amounts of wheel spin based on the conditions you are actively driving in.
(1) Mud & Sand, (2) Loose Rock, (3) Mogul, and (4) Rock. The first setting allows the most wheel spin and as you move through them up to Rock, it allows almost no wheel spin.
· Allows wheel spin
· Controls throttle
· ≤ 7 mph in 4L
o MUD & SAND: The front-wheel drive control lever is in 4L or 4H.
o LOOSE ROCK, MOGUL and ROCK: The front-wheel drive control lever is in 4L.
· Active Driving
Crawl Control
Designed to maintain a constant speed. You just steer. Lurching, vibration & noise are normal in pre-2024 models.
· Must have engine On, Foot on Brake, in 4L, shift in Drive (not Park or Neutral), Driver Door Closed.
· Select Crawl Speed
o Lo: rocky roads or decline
o Lo-Mid: rocky roads, decline or bumpy incline
o Mid: bumpy inclines
o Mid-High: bumpy inclines, debris roads, snow-covered roads, muddy roads, gravel roads, grass roads
o High: bumpy inclines, debris roads, snow-covered roads, muddy roads, gravel roads, grass roads
Ø Downhill: Mogul & Gravel, Speeds 1-2
Ø Uphill: Mogul Speeds 2-5, Gravel Speeds 3-5
Ø Flat: Rock, Snow, Sand, Mud, Dirt, Grass Speeds 1-5
· Turn Crawl Control On
· Foot off Brake and away you go!
v Not Recommended:
o Extremely Steep Inclines
o Extremely Uneven Surfaces
o Snow-Covered roads
o Other slippery surfaces
§ Uphill with snow, sand & other soft surfaces (mud) requires momentum
v Automatic Cancellation (limitations for prolonged use where lockers may be preferred):
o Brakes Overheat
o Transmission Overheats
o When driver door opens
o Vehicle speed exceeds 15 mph
o Shift in Park or Neutral
o Shift to 4H
o Any system malfunction
Rocks
v Tires on Top
v Vehicle Level
v All Tires Touching
v Protect thumbs from steering wheel spin
Rock Step Ups
v Approach angle / Ramp Breakover Angle / Departure Angle
v Vehicle length
v Stack Rocks, tree branches…
Max Trax
v Bump It
o Controlled Landing
o CV axles at risk for hard landing
Vehicle Height with Roof Rack = 6’6” or 78”
Vehicle Total Weight Capacity = 950 lbs
Dynamic Roof Weight Capacity = 165 lbs
· Morrflate 20 lbs
· Tool Bag 32 lbs
· Roam 95L Rugged Case 25 lbs
· Shovel 3.5 lbs
Resources
■ AHB (Automatic High Beam) ®P.244 ■ PCS (Pre-Collision System) ®P.270 ■ LTA (Lane Tracing Assist) ®P.282 ■ LDA (Lane Departure Alert) ®P.290 ■ LCA (Lane Change Assist)* ®P.287 ■ FCTA (Front Cross Traffic Alert)* ®P.302 ■ PDA (Proactive Driving Assist) ®P.296 ■ RSA (Road Sign Assist)* ®P.304 ■ Dynamic radar cruise con trol ®P.307 ■ Cruise control ®P.318 ■ Emergency Driving Stop System ®P.321 ■ Traffic Jam Assist* ®P.324 ■ Driver monitor* ®P.268 *
I don't think I've been above 3rd gear in 4LO. This forum thread discusses your experience.You guys getting all 8 gears in 4LO? Mine is just 1st - 4th.
Being more of the slow as possible, fast as necessary type I never went above 4k rpm in 4lo. I realize it’s no V8 but I prefer to keep rpm low in 4lo. Though, with your results I’ll go out and flog it and see what happens. Sure seems wild to me Toyota set the shift points at such high engine speeds in low range.I did a quick test and confirmed it will shift at least up to 6th - I wasn’t in an environment to hit speeds to take me up to 8th. This is a rough approximation based on what I was able to safely observe while driving, certainly not scientific:
(Test on a 2025 TJH250L-GNZAZA, though I imagine this is the same through 2026 models)
- 1 to 2 upshift ~ 3.5k RPM
- 2 to 3 upshift ~ 4.5k
- 3 to 4 and so on up to 6 at ~5.5k
I will say it did not feel good at all to be in 6th gear in 4 lo!Being more of the slow as possible, fast as necessary type I never went above 4k rpm in 4lo. I realize it’s no V8 but I prefer to keep rpm low in 4lo. Though, with your results I’ll go out and flog it and see what happens. Sure seems wild to me Toyota set the shift points at such high engine speeds in low range.
What is A-TRAC?Here is a summary of Pearls I garnered when I got my LC 250 in 2024.
A-TRAC
o ~ ≤ 5 mph
· Allows wheel spin
· Controls throttle
· ≤ 7 mph in 4L
· Active Driving
Sorry all. That is not very clear. It is conflating info for the 4Runner with the Land Cruiser 250. Here is an explanation from @BlueCruiser on another thread on our forum:What is A-TRAC?
What is the Front wheel drive lever?
For beach driving, the biggest things are tire pressure, maintaining momentum, and avoiding sudden steering or braking. I'd air down the tires appropriately for the sand, usually around 15–20 PSI depending on the conditions, and carry a reliable compressor so you can reinflate before getting back on the road. I'd also keep traction control settings in mind, as some systems can limit wheelspin when you actually need it in soft sand. Avoid using Crawl Control or low range as your default for cruising; they’re more useful for specific situations. If you start getting stuck, stop before digging yourself in deeper, gently reverse along your tracks, and use recovery boards if needed. Most importantly, check the tide, avoid driving alone, and bring recovery gear. Have fun with the 1958!What’s up LC community.
Next weekend, I’m gonna be taking my 1958 on the beach for the first time. I’ve done quite a bit of beach driving before (different truck) I just wanna throw this out there if anybody has any pointers. The beaches where I live when the sand is hot can be very soft and I’ve seen even some of the best off-road vehicles get into trouble.
With that being said, just wondering if there is a specific set up, I should set my car up in when I am cruising on the sand. And also what would be best if I find my self in a bit of trouble.
For example traction on or off. What mode to leave in. Do I just start out in crawl, L4 etc etc. my previous truck just has a “sand mode” and I would leave it in that and it performed really well. 1958 doesn’t have that but I think the LC LC does. click here for more information. Any recommendations would be great!
Much appreciated![]()
This was caused, primarily, by stupid drivers. Drive sanely and this is easily avoided.There's a post somewhere on this forum of someone cracking their radiator bc the skid plates are mounted the same place as the radiator bracket. So they slammed the skid plate against sand, and that pushed the skid plate in against the brakcet causing the radiator to slam.
I think it was compounded by them airing down for more traction? I suppose go slow and be careful of dunes as to not slam your front end against sand?
I disagree. It’s really poor design to have the skid plate mounted to the radiator support beam. The skid plate is intended to take impacts, and what it’s mounted to isn’t.This was caused, primarily, by stupid drivers. Drive sanely and this is easily avoided.
Some inmate on this forum noted his was bent, and he didn’t even know when or how it got bent.. ie he was never driving like a crazy person..This was caused, primarily, by stupid drivers. Drive sanely and this is easily avoided.
What tires did you have when you did this?All I do is air down to 20psi and put it in sand mode. Been in some nasty deep soft sand on the outer banks of NC and the LC didn't miss a beat.
I’ve been on sand in everything from street oriented ATs to aggressive/rugged terrains (Ridge Graps, Mickey Ts, Duratracs). Digging in, rutting and getting bogged are not mutually inclusive. You can get just as stuck in a street tire, and being unable to dig in and out is, IMO, worse than having something that throws sand.What tires did you have when you did this?
I recently added Bridgestone Dueler AT Ascents, so i could be part of the ‘kool kids club’, but then found several sources that claimed the AT tires with a knobby design tend to dig in more in soft sand, than say, the OEM tires..
I think SandTow (YouTube and FB) would agree with you.. I grew up in Daytona Beach, and these guys are always yanking people out when they get buried on the beach..In short TLDR, your tire will be fine and I’d argue more capable on sand, soft or packed.
