Anyone have experience with Bison Gear?
Thanks for the tip! And for the pics in actual application. What kind of doggo?
He is a golden doodle mix we saved from an Amish puppy mill breeder. He is now spoiled and gets a booster seat in the middle between the kids.
My full Bison Gear system (panels, shelf, divider) is due to arrive today! Will give feedback after install, but updating here to let all interested know that shipping took less than 2 weeks from Poland. That's only about as long as it took Victory 4x4 to simply respond to an email regarding their system. Bison still has the discounted pricing on their website, and my order total was right around $800. Hopefully Fedex doesn't play Fedex games and I can update by week's end.
Reactions: jtc
Installed and Maligator approved. Took about an hour start to finish only requiring my wife’s assistance starting the hanging bolts on the shelf with me under.
Definitely exceeds expectations and I highly recommend. Just a couple transparent gripes that I find minor:
1) I will need to add a couple nylon washers behind the magnets since they are just a hair shy of making contact to adhere in the up position.
2) The mounts that are held in place by the headrests have an afterthought design, but they do the job. They did their best to accommodate all possible rear seat incline options, but excelled at none of them in a way that makes it feel fully locked in or consistent with design.
Again, highly recommend as the quality is top notch and it looks excellent. Feel free to ask any questions!
Day 3 update (and fix) for those who are experiencing the same thing I did, or those who order down the road:
After about an hour of drive time I began noticing a rattling. Hard to isolate so I wound up softly tapping every panel with a light duty mallet. I was able to isolate the rattle (loose metallic sound) to the swinging gate/divider’s 2nd row headrest brackets. Specifically, the holes that the headrest post slide through are significantly larger than the posts themselves. Very annoying with even minor bumpy terrain.
This is a design element, not a flaw. Everything about this system is built with the ability to make adjustments up/down, left/right and forward/back. It is also a system that has to account for various 2nd row incline positions. They created a bracket that is rigid but able to accommodate a variety of angles positions. There is no one “right” position, and thus it works good as a form to fit product. It does not, however, excel in any single position, thus the rattling of the bracket as it shifted against the metal headrest posts.
The fix: 1/2” rubber grommets (x4). See pictures below. It requires elbow grease to slide the posts through, but it is snug left/right and forward/back. It still allows the union to pivot up/down for various incline positions, and it allows for some left/right manipulation when achieving a snug connection. IMO the divider kit should just have 4 of them as supplied hardware, and I plan to provide Bison Gear with that recommendation. $10 total at my local Home Depot and no more rattling.
Hope it helps. Simple and underserving of the detailed writeup, but I had to account for those considering the system not having a clue what I am talking about.
any rattling with or without stuff on shelf?
I gave it a bit for the person you asked to answer. I have zero rattling from the shelf or the mounts, loaded or unloaded. I haven’t actually weighed my loadout there, but I would guess I keep anywhere between 2-15lbs up there (depends on if I have my pup with me or not).
Anyone have an issue with the width of the shelf brackets, when mounted, being slightly too wide for the shelf? I'm waiting for some help this afternoon, so haven't tried to align and tighten the bolts yet, but seems to have a lot of gap.
Share a pic, I’ll see if I can help
It was too tricky to get a good pic by myself, but here is a pic of the passenger side bracket, mounted. When the left side of the shelf is pressed flush against the driver side bracket, there is a good 1 inch gap (probably more) between the right side of the shelf and the passenger side bracket.
I just took a look at a few other pics in this thread and it looks like I have to flip the brackets around. Will give that a shot.
I can share whatever pics you need too. I loosely installed the brackets first to the shelf, and then mounted the shelf/brackets as one unit.
The bracket in your photo is correctly oriented
Thanks DubDub - are your brackets flush with the inner lining all the way down to where they straighten out? I'll try your approach to see if I can get that to work, but there really is a good 1-2 inches of gap. I'll give it a shot.
I also have the window molle panel brackets behind the shelf brackets, but yes it was fairly snug up to where it angles away for a perpendicular mount for the shelf.
If you have it finger tight to the shelf first, I think it would form up naturally… or at least appear to as you’re tightening it to the body.
My shelf and brackets are stamped with GX550. Do you remember if yours were too? I wonder if there is a slight difference between the GX550 and the LC250.
Yes, same kit and all of them say GX550
...nice spokesdog...
I just installed the Bison Gear molle panels and shelf this morning and am really happy with it. I had a smiliar setup with Rago in my 5th gen 4Runner and it was twice as heavy (at least it felt that way). No rattles either but I took the advice of some other’s that posted and loosely assembled everything and then worked my way from the bottom up.
