Air Conditioning
GS302
9
5
Delaware
Jeep, waiting on a LC allocation
Finally got hot here on the East Coast and I'm running the air conditioning on my '25 LCLC. It is, by far, the weakest AC I've ever had in a vehicle. The air is cold, but the amount of air blowing out of the vents is pretty poor. Anyone else experienced this? Trying to figure out if its an issue I need to have looked at.
Mine seems to be fine...if my LC has been sitting in the I'll crank up the fan to level of 4 or 5 bars (out of 6, I think?) for a bit to cool it off quickly, but generally only need the fan at level 2 to maintain comfort...including during a 50 mile trip during the day yesterday in 95°F+ heat, with the thermostat set for 68.
Make sure not on Eco on AC or drive mode
Mine was fine at 94 degrees this morning, at 11 am, might help to kick on the rear A/C also
1 - If you are driving in ECO mode, the A/C is weaker. When it is HOT that may be a bit of an issue. I personally just do not run ECO as the MPG difference is nominal at best.
2 - Do you have the rear A/C on?
3 - If you have a sunroof you may want to close the blind to help.
If it is almost 100F, it is going to take some time regardless of vehicle.
