I didn't want to completely stuff the wheel wells so opted for the 285/65/18, the lift really tied it all together. I don't have any data on stock clearance since i did the lift and tires at the same time.Amazing. We just got a 2026 Underground LC and are trying to decide on lift and wheels. I have a bit of anxiety about loosing a warranty, but it looks soo good with the lift. The tires look like a good size too. Any reason you didnt go bigger tires? I think I can fit up to a 285/70/18 without a lift. Wasnt sure if yours was leveled before you put tires on.
I thinking I’m going the peak 1.25 route? Was it actually level or did it cause reverse rake? Rides smooth like stock or was it a bit more harshHappy new owner of a 2026 and have already installed 18" methods with 40mm back spacing and 285/65/18 Wild Peaks. I also put on a PEAK 1.25" top hat spacer but will be replacing it tomorrow with the Westcott lift kit for a little more height. Love these cars!
I didn't take measurements but it looked pretty even front/rear when i was parked on flat ground. No change in suspension from stock.I thinking I’m going the peak 1.25 route? Was it actually level or did it cause reverse rake? Rides smooth like stock or was it a bit more harsh
