1958 owners upgrading from 245/70 to 265/70/18s
d30002
Seattle
LC250
Hi all,
I’m not a big fan of the stock oem 18 wheels and the 245 tires.
I’m considering buying a Land Cruiser LC trim take off wheels set 18s with the Michelin 265 oem tires.
Then I’ll use the old wheels for winter tires.
Has anyone done this, worth the upgrade?
Many have done exactly this and shared their experiences. If you use the search bar (top right corner of the screen) you will find exactly what you’re looking for.
This is well discussed for sure. It is also the first mod a discerning 1958 owner should perform, if they care about the accuracy of their 1958’s speed, distance and efficiency reporting.
I did not go with LC wheels, but I did go with another Toyota OE option with a 32.6” equivalent tire size. The LC trim wheels are an excellent option though, and fairly consistently available. I’m actually going to run these 286/65s down to 5 or 6/32 and install 275/70s.
If you want to consider the other OE options available to you, visit this thread: Tire (and a few wheel) options spreadsheet
I am also willing to discuss fitment concerns from a 1958 perspective, just send me a message.
Sorry guys my bad! I normally do search, dropped the ball!
I’ll be selfish and accept it as just another opportunity to rant about my only legitimate complaint with the 1958. Toyota putting 245s on LCs calibrated to 32.6” diameter for (what I assume to be true) regulatory reasons, knowing the indications are false, is criminal IMO.
Here are some pics of my 2025 LC 1958 with 265/70-18 Bridgestone Dueler Ascent tires on the OEM 18"x7" wheels:
This is the way -- upgrading from 245s to 265s on a 1958.
Went Toyo AT3 SL (not LT) since I'm snow (not offroad) focused -- been great!
Welcome to the asylum @d30002.
Going to a larger tire, 245 to 265, will cost you at the fuel pump, even if they are the Michelin ATX, which are very light weight.
I gave away my OEM 265 Michelin ATX tires (5) with 35,000 miles on them, to another inmate with a 1958 when I had 265 Bridgestone Duelers installed.
Last I heard from him, he is very happy with them.
I was able to find a set of five 18 X 7.5” Toyota wheels at a local wheel repair shop in Marietta Ga to mount my Michelin Ice tires on.
As a 1958 owner, I focused on the inverse argument to your point. Yes, OEM 245 Geolanders are 11 lbs lighter than the OEM 265 Michelins. This matters, but how much? And, how many 1958 owners are actually aware that their 1958 is travelling 3.5% slower, and 3.5% less distance than what their dash is telling them? For every 1000 indicated miles a 1958 owner on 245/70s travels, they are giving away 35 miles.
Another, and I’d argue more significant consideration is the revs per mile. Yes, the weight helps efficiency overall, but those 245s require 22 more revolutions per mile, and on a full-time 4WD vehicle. That means that if you want to actually go 60 mph on the freeway, you need to go 62.2 on your speedo, and both factors require a higher engine rpm to maintain that speed.
So the question for any 1958 owner becomes: Is accurate indications and reporting more or less important than the extra .5mpg you may or may not be achieving, but will only truly know about with some algebra?
Are we certain that 1958's are factory calibrated to 265/70/18? I switched from the stock 245's to 265's early on and my odometer with the 265's consistently records about 3% less than the actual miles driven. i.e. when I drive a 100-mile marked stretch my odometer says I drove only around 97.5 miles. The 3% difference essentially being the difference in diameter between the 245's & 265's. So my takeaway is that the 1958 odometer (at least mine) is factory set for the OEM 245/70/18 tire.
Either way, switching from the 245's to a 265 (or 275) should be a no brainer for most 1958 owners. Tire Rack currently has 2 choices for the 245 while you can choose from 107 options for a 265. Kind of odd Toyota went with the 245 size to begin with. I've had virtually no change in gas mileage going with the bigger tire.
As far as I know, there is one calibration for all LC250 trims. The Speedo (and odometer) are calibrated to be conservative rather than 100% accurate. I checked our Premium against a GPS Speedo phone app with OEM 20” wheels and tires and found it to be under-reporting by 3-4 kph at 100kph displayed on the speedo.
After switching rolling stock to 275/70/18 I found it to be accurate….for a very brief period, and then it was back to under-reporting with similar margin of error when compared to the same app.
Not calling you a liar, but I am highly suspect of this info. It has been confirmed by quite a few, including myself using external GPS, that the error is grossly misaligned with 245/70 31.5” on 1958s. Even after switching to 32.6” tires my reporting indications are low, consistent with common manufacturer practice. Some members, again including myself, have inquired Toyota and dealerships IRT a calibration, to which the reply has consistently been that none can be performed.
I stand corrected.
No offense taken. All I can say is what my readings were with the 265’s. On the long stretch of Maine highway up to and back from Acadia. I did two 100 mile marker tests, and both times my odometer said I drove 97.5 miles.
If the reason Toyota put 245’s on the 1958 in was to increase the EPA mileage ratings (however negligible) you’d think they’d at least calibrate the odometer accurately from the factory. But I guess the moral of the story is your mileage may vary.
Do a GPS run. I’ve personally found Google Maps to be nearly comparable to my expensive portable unit. Look at speed over ground vs what your speedometer is saying. If you are under or at indication with minimal error, your odo is as well.
Mileage may vary indeed, although it is a very interesting exception.
So I went ahead and did science. Partly because I am feeding data to a couple other members on a side research project, but also because enough time had passed that I started second guessing myself. So… I geared up and wasted some time trying to verify or disprove my claim to 1958s being calibrated to the 265/70-18 diameter of 32.6”.
Setup: 2025 1958 on 285/65-18 (32.6”) tires. I did two individual runs at 10mph increments up to a sustained 60mph commute. One rural where I live on the way to work. One in the city at work on the way home. Datapoints taken via speedometer, google maps, and my Garmin handheld GNSS device w/ fidelity to the tenths. Spent enough time at each speed to take three readings spoken into voice-to-text. Averages rounded to tenths for GNSS.
1) To work (rural):
Speedo / Google / GNSS (Error)
10 mph / 10 mph / 9.9 mph (1%)
20 mph / 20 mph / 19.8 mph (1%)
30 mph / 30 mph / 29.6 mph (1.3%)
40 mph / 39 mph / 39.5 mph (1.3%)
50 mph / 48 mph / 49.3 mph (1.4%)
60mph / 59 mph / 59.2 mph (1.3%)
2) To home (populated):
30 mph / 29 mph / 29.6 mph (1.3%)
50 mph / 49 mph / 49.4 mph (1.2%)
60 mph / 59 mph / 59.3 mph (1.2%)
Averaged out, this means that my 1958 is still reporting/indicating a 1.19% error. This means that at any given speed I am indicating 1.2% more than actual SOG. This is consistent with a conservative calibration error one would expect on a factory specification vehicle.
If I were to be in 245/70-18 (31.5%) tires this would only be exacerbated. Actual SOG error would be 4.53%. So I stand by my claim that, at least in the case of my 2025 1958, it was factory calibrated to the 265/70-18, 32.6” tires size.
Edited for disclaimer: I am a flatlander and my elevation change from home to work is 14-24 ft over 40 miles travelled. SOG is impacted by elevation change, but I have none.
Alright. My interest is at least piqued on this subject now.
My 1958 is still bone stock with 1000 miles on the clock. I’m going to toss my Garmin GPS in it tomorrow and run it on my way to and from work tomorrow and see what the stock variation looks like.
Next week on Wednesday I’m having 275/70’s installed and I’ll repeat and see how it looks.
Latest Discussions
