My Land Cruiser came with the Michelin LTX road tires, which are super soft and comfortable. I have an extra set of BFGoodrich that I switch out for off-roading trips in the winter and generally keep on through the winter. These are some KO2’s that were on clos out. . Size is 265/70/18. I know that my Michelin tires it is recommended on the door sill to run at 32 pounds. I’ve been running these BFGoodrich at a little higher pressure (34-35) but they’re definitely stiffer and tighter. What would you guys recommend for highway pressure? Is the factory 32 too low? I plan to lower them down to 20 to 25 for offloading in Colorado . Thanks in advance.!
