my setup would be
Def Snap shade over moonroof. Rear window set seems would/could be great, not sure where the small gaps are, possibly an easy fix.. pretty pricey tho.. for me.. I’d rig screen fabric,
Back glass up, I rig a breathable tapestry, maybe draped over, tucking bottom in at bumper..maybe?
There’re small Evap cooling fans, little power draw, run it off port batt bank.. or just small fan.
I’d def have a plug in cooler/freezer unit, with solar charger, bring it down daytime, off in eve to reduce heat, humidity, toss a freeze pack in fridge side every eve if needed.
Engine on standby, running AC, misc, etc, at idle even for 30 min on a daily, is not a good idea. Extensive idle, maybe numerous open loop (cold starts)if AC does kickoff 45 min or so,.. how does run time factor w/routine maintenance? And other parts, plastics; hoses, etc. wear cycles(not sure if correct term).
