turbo upgrade lc250?
liftedlc250
united states
land cruiser lc250
Ive been looking into power mods for my lc250 and theres a big turbo replacement has anyone installed it on their land cruiser and what supporting mods are necessary? Also disregarding the turbo any power mods to really make the lc250 faster?
Recommend entering “turbo” into the search bar. Read and contribute to those threads. Maybe more specifics than “big turbo mod” if you want feedback. Good luck.
Couldn’t find any results on here from anyone posting about an upgraded turbo. The only turbo kit that appears to exist is Big dawgs tk500 stage 3 turbo which is what i’m curious about. Little information on the site but i’m assuming some people in the space might know something about it.
That’s a real expensive proposition you’re considering.
Kinda hard to make a 5000# AWD brick too much faster.
TeqSport has some info. Claiming upcoming T24A ball-bearing turbo soon, & you’ll need their +70hp tune, swap charge pipes, CAI, larger turbo inlet & throttle inlet, intercooler, cat-back exhaust, etc… maybe making 375-400hp & probably just south of $10K will get you there. And it won’t be any faster, maybe a wee bit quicker.
I am vaguely familiar, but you’ll have more luck asking about that turbo/tune in the 6G4R forum or tacoworld. I’ve been down this road in high compression, low displacement Subies… though the LC isn’t a Subaru, it is both of those other things. Good luck.
yea i’m aware it won’t be insanely fast but i hear that with just a tune it’s already pretty woken up. Also big dawgs says they can make up to 500 engine hp with the proper tune and mods supposedly. I don’t think i’m too likely to go big turbo definitely not anytime soon at least but I’m definitely planning on a tune and intake so I was wondering how much supporting mods will even be worth it. What mods do you think actually matter for increasing performance without going overkill money wise?
Performance means a lot to different people.
These are really pretty unique & fascinatingly advanced AWD machines. Heck I haven’t even figured out the charging system really works yet.
Dub nailed it that it’s a low displacement / hi-output powertrain w/ the miracle of turbo-inter cooling & a unique hybrid system providing unreal torque. We’ve got owners breaking CV shafts @ stock HP rock crawling.
What to start with - Just me, but I think the induction system has 2 big issues w/ a restrictive turbo inlet & throttle inlet that could recover some stolen HP. 2.75”-3” Exhaust over the 2.5” would be next. Then there are owners that just skip all that & do a tune.
Nitrous. Relatively cheap. I came from a highly modded turbo 4cyl, it gets expensive fast and you will always want more power, and have to keep modding as a result -as the vehicle destroys itself. Not to mention driveability/reliability and resale tanks.
Buy a braptor with the power upgrade, or a wrangler 392 and supercharge it.
You bought the wrong vehicle, the LC 250 is 6,000-lbs. It would take several hundred more horsepower and a lot more displacement and/or boost to build a torque curve and peak at the RPM that would make it feel 'faster', it already has a massive amount of e-torque added off idle in sport mode. At the end of the day, it's a 2.4-ltr engine, or better yet, around 146ci producing 275-hp. That's the equivalent of a 302ci 5.0-ltr V8 producing 550-hp. I would go with what Banks is offering as I know all of their products have been thoroughly tested and vetted (they built +2 psi of additional boost which will increase power substantially), and just understand that all the 'power' will typically only be felt through WOT and at the top of the curve. It will never be even remotely 'fast' compared to any modern car, but it's very quick from 0-40 MPH already for what it is.
You aren't dealing with a conventional system that you can easily upgrade torque converters, fuel systems, transmission valve bodies, differential gearing or even minor drive line components like axles, etc. Again, wrong tool for your application. I wouldn't trust the drive line Toyota put under this with ANY increase in power. They don't overbuild anything. Unlike my RAM Power Wagon which is absolutely bullet proof, with all the running gear from a Diesel with less than half the torque.
I would be buying a 392 Jeep Wrangler or 5.0 Coyote (V8), single cab Ford F-150 XLT trim with a rear locker, 10-speed with 3.73-4.10 gears, and toss some money in tires and suspension. There are many, many options out there for a 'fast' off road vehicle, placing reliability aside.
