Subwoofer yet?
I'm running a full system.
Focal Evo Flax 3 way system up front, coax rear, JL12W6 in a sealed birch box, Ampro, Mosconi 8.10 DSP, and an Alpine R7 amp for the sub, and tuned.
Hi, I want to do this same thing. Can you explain how you ran the power wire from the amp back to the rear battery? And how did you route the cables from the Beat Sonic to the amp under the seat? I haven't done much car audio work so any advice and pointers are very much appreciated!
Beatsonic has a plug and play harness to grab power under your seat from the power seats. I haven't done the Sub yet but I had the discussion with Beatsonic You just unplug the power seat connector and plug this in the middle of the circuit.
If you pull the plastic panels off that are along the door floor, you can get under the carpet/floor area. Basically, there is an elevated area under the carpet, and you can run wires through that area pretty easily. I use a fiberglass rod, attach the wire, and just work it through to the area you want it.
Basically, you can get wires all around the cab by working along the doors and inside the wheel well area. It all just pulls apart and allows pretty easy access to string wires wherever you want.
The premium audio system is average at best. I installed a sub among other components.
• Amplifier Integration Interface for Select 2022+ vehicles
• JL Audio VXi Series 8 Ch. Amp w/integrated DSP
• WavTech link500.1mini (sub amp)
• JL Audio TW3 Series 10" Thin-Line Subwoofer Dual 4 Ohm 400W
• JL Audio 2.75: Component Midrange Speakers (2)
• JL Audio 1" Component tweeter, Sing.e (2)
•. JL Audio 6.5" Component Woofer (s)
• JL Audio C3 6.5" Convertible Component/Coaxial Speaker System
But does it thump? :LOL:
