From what I’ve read, collar lifts and preload collar lifts all increase static height but also decrease actual suspension travel or articulation. Makes sense, as the car sits higher but the actual endpoint of extension is the same.
Would I be correct in assuming all aftermarket suspension lifts kits like King, Icon, Dobinsons etc all have a slightly longer shock to then allow for more extension/droop even after the lift? This is, assuming the UCA is not the limiting factor for droop, but in fact the shock length.
For a modest for of 1-2”, I assume the shock should not bottom out so I should not need extended bump stops correct?
Preferably, I want to keep the lift modest so I can just get new shocks and springs without new end links and all the other components.
Thanks in advance
Thanks in advance
