I was at the Annacis Auto Terminal to drop off some export units to Japan and spotted a few new 4Runners for the first time. About 2 dozens of LCs are believed to be on the same vessel. You know what! I like my LC more than new runner for sure!
It's not all that clear to me how there would be a difference in ground clearance between the new 4Runner and 250, since they share the same frame and suspension.I wish the LC came with that much lift/ground clearance stock.
Likely due to the shock package different trims get. TRD OR 4Runners get a bilstein 4600 which may be a tad taller than the tokicos that base models get.It's not all that clear to me how there would be a difference in ground clearance between the new 4Runner and 250, since they share the same frame and suspension.
Couldn’t the rear wheel well space could be due to the different body shape and not necessarily the ground clearance of the vehicle? I always thought ground clearance was due to the ladder frame and suspension components.It's definitely taller. Look at those rear wheel wells. You could stick your head in there haha. Same tire size too.
Would taller shocks reduce down travel?Likely due to the shock package different trims get. TRD OR 4Runners get a bilstein 4600 which may be a tad taller than the tokicos that base models get.
I would imagine not? I am not a shock guru though… that said, everything I’ve seen on shocks, like the bilstein 5100, suggest that the extra length does not limit up travel. I think there’s a lot of factors at play though and there’s not a simple cut and dry answer.Would taller shocks reduce down travel?
True. We’ll have to wait until someone measures Ramp Travel Index (RTI) on these.I would imagine not? I am not a shock guru though… that said, everything I’ve seen on shocks, like the bilstein 5100, suggest that the extra length does not limit up travel. I think there’s a lot of factors at play though and there’s not a simple cut and dry answer.
My guess is that the TRD OR will be below the LC FE w/SDM that was tested on car&driver as they do not have the SDM. I’m not sure if the TRD OR have the same double offset CV axles that the 4th gen Tacoma has but if they do that may help a bit in addition to the bilstein 4600 shocks that they have. I find it strange that LCs have the tripod CV design which limits a bit of travel. Overall thought I think the TNGA-F vehicles outperform their J150 counterparts.True. We’ll have to wait until someone measures Ramp Travel Index (RTI) on these
