Maximum electrical load for rear (cigarette) accessory port
I have Viair 300p - alligator clips have an inline fuse with a 40 AMP. Not sure if that helps for running power. Thinking about putting Quick connects coming from battery to quick connect on the Viair cables to run power. Instead of the 7 Pin .
Here you go:
Broken link..
I have been using this 7-pin adapter to power the Viair 84P/85P inflator from the rear exterior 7-pin port without any issues:
I bought it on Amazon, but Tractor Supply may have it at a lower price currently.
Second this, I have the 400P EF A [30amp max] and it works well with 7-pin port. It connects and disconnects quickly.
Just to clarify further, the Viair 84P has a round 12V connector and a 15 amp rating. I have been plugging that into the round 12V port on the 7-pin adapter (Amazon link above), which in turn is plugged into the LC's 7-pin exterior trailer port.
No problems with this arrangement.
