Let's work through your logic here.Spoiler Alert
Most Toyota owners who drive offroad are usually concerned with the following:
Hence the reason for properly setting up their vehicles with light weight wheels
- Range/MPG
- CV axle longevity
- Transmission, Transfer Case, Engine Temps
- Power/Torque
First, you are talking about spending at least $3k in new wheels/tires (x5).
Now, in your OFFROAD situation, what exactly is lighter wheels (and heavier tires) going to get you in MPG when doing 20-30mph (max)? An extra 1mpg? Great...you just bought yourself 20 miles. I'll even give you 3mpg - 60 miles. Better Solution: Buy a gas can. 2.5gal rotopax gets you ~40 miles. A 5gal jerry can - 80 miles.
CV axels? Really? Spend $800 and upgrade your axels. A much better solution.
Temps? What exactly is a lighter wheel going to do at 20 (or less) mph? Absolutely nothing. On a highway, maybe, but again - you said OFFROAD.
Power/Torque? That's the motor/transmission/diff gear ratio, not (necessarily) the wheel weight. But lets say you gain 10% (a wildly high number) vs stock by using a lighter wheel. You really need 510ftlbs of torque (and you are worried about the CVs?)? I'm pretty sure that 465 is just fine. Even 420 is more than enough.
So, you have two situations where for OFFROADING, the lighter wheels are basically meaningless, one where you can mitigate the situation with a $30 gas can ($100 if you want to overpay for rotopax) and $20-$30 worth of gas, and the other where spending $800 would be the real solution....vs $3k+ and still doesn't solve your first two problems.
If you want different wheels, there are logical reasons - different diameter (esp 17"), different pattern (looks). But making claims that a lighter wheel is somehow going to make offroading much better is a stretch.
