New here and have some questions...
MassLC
MA
2026 LC 1958, 2017 4Runner SR5 Premium
Hi all. Bought my first LC, 2026 1958 Ed., a couple of months ago. Previously owned a 2007 Tacoma and still own a 2017 4Runner.
Planned upgrades are roof rack and new tires before the end of the year. Tires will most likely be BFG KO3s.
Roof rack...still trying to figure that out, looking between:
  • Prinsu
  • Westcott
  • Sherpa
I don't really do any overlanding per se, but travel throughout New England a lot hiking, fishing and snowboarding. I really need something to get my Thule box up on, ideally along with my snowboard racks. Maybe down the road some rod tubes and an awning. The Sherpa seems like the easiest install, but they are all pretty similar. It is also amongst the most expensive. Opinions? I have read through many of the threads so have probably seen many of them already, but any specific feedback would be appreciated. I think I am going to need the Thule rack extender thing for any of them to accommodate the cargo box. I was also thinking that maybe I could not use all the provided cross bars and the box would sit down recessed within the rack a bit. Not sure if that would work or not.
One major question: Does anyone know how to reliably disable the backup camera and automatic braking when towing a trailer or when a bike rack is attached to the hitch? I think I disabled everything and the system is still slamming on the brakes while backing up.
Pic of the new truck and one alongside my 4Runner.
Left of the steering wheel there is a symbol of a vehicle backing into a large cone with โ€œsparksโ€ floating around it. Press that button and try it again.
To disable the braking when you back up with a bike rack etc., push the button to the left of the steering wheel with a cone and explosion symbol. In the settings menu in the driver's display, โ€œP radar coneโ€ off to stop the audio alarms.
Congrats on the Land Cruiser and welcome to the forum (y)
There are channels with trim in them on the roof- models that came with OEM roof rails have one type, and models (such as the 1958) came with longer filler strips. All models have the securements for rails under the trim strips.
If you are going to add a rack system you may also need the trim from the LC/LC, Premium or FE editions to make the roof look finished when installing your rack of choice. I am not aware of any aftermarket racks that come with these trim pieces, but then again I haven't investigated much.
As for tires, the K03s are seeming to be a pretty great tire- you'll want to be careful with sizing if you'll be mounting on the 1958 rims, as they have more negative offset than some other OEM 18" options and could potentially rub. There is a very long wheel & tire thread (amongst others specific to the 1958) that may cause information overload, but discusses the tires that work and some caveats you'll want to be aware of.
  • Prinsu
  • Westcott
  • Sherpa
Great looking rig. Are you planning to run e loads?
  • Prinsu
  • Westcott
  • Sherpa
Congrats and welcome from KY. I have factory rails and crossbars on 250 but love my Prinsu rack on my 80 series.
Hadnโ€™t thought too much about that. Was thinking 265/70-18s. I believe I found on here there was no issue with rubbing at that size. D or E load wouldnโ€™t make too much difference for my use of winter travel, dirt roads and some class IV roads other than weight and MPG as my daily driver. Do you have thoughts on it?
I like that size on stock height/suspension. Iโ€™m running Falken Wildpeak AT4Ws in an E-load rating in that size. Theyโ€™re awesome tires, but theyโ€™re heavyโ€”Falkens tend to weigh more than comparable options. I suspect theyโ€™re costing me around 3-4 mpg compared to an SL-rated tire. Again, might not be as drastic with other tires as with Falkens given the weight.
Your choice really depends on the terrain. If youโ€™re planning to tackle rocky trails, the 10-ply E-load is a great option for the added durability. Otherwise, I think a C-D load tire is a nice middle ground. Another solid choice is the Toyo Open Country A/T III in an SL load ratingโ€”itโ€™s a more aggressive SL tire while staying noticeably lighter than an E-loads if MPG and improved off road capability from stock is a priority.
I have a 2025 1958 with Ridge Grapplers. I am on pavement or beach sand. I have never aired down and have never gotten stuck. I had 2 Sequoias before the LC so have been driving on sand a long time.
When it comes time for tires, I would consider the KO3 or Grapplers again. Although, many on this group speak well of the Toyo. Not much snow in Coastal NC. I still have time. Only 16k on the odometer.
Great looking rig--congrats!
We sell significantly more Prinsu than Sherpa but both are very similar in design. I would also recommend checking out Front Runner offerings as they're extremely modular and they make mounts for just about anything you could imagine.
For tires, that size will work perfectly on your stock wheels and does not require a lift or spacers. If it's primarily a daily driver, I would stick to C loads if not SL tires as the ride quality improvement is worth it IMO. If you're off roading a significant amount of the time, E loads start to make more sense but they absolutely come with a ride quality hit. Good luck and keep us posted!
