They want to kill the phone home connectivity for privacy concerns.Why would you remove it. Is there an after market alternative that is better than the Toyota branded one?
Installed today.. not a terribly difficult job. I removed the negative cable off the battery first. Also, have your head unit code ready to go when you hook the power back up. I did find the video below helped a bunch for the trim removal.
Where do you find the head unit code?
Did I see that in the owners manual once maybe?
iOS has been doing that long before iOS 26 was released. I spent a couple of hours on the phone with Apple Support trying to figure this out with them, and we could never get to the bottom of it. But it seems to be working okay nowShowed my location about a mile to the right of where I actually was the entire 30 mile trip... and giving me directions to get back to the road I was on.
Question/Clarification : does pulling the dcm fuse kill the “voice command” microphone, or the microphone for making phone calls? If the former, I’ll just pull the fuse as voice command just sucks and never gets any “voice command” right, so worthless and no loss to me. If that’s the only issue, fuse is the way to go over tearing into my console or dash.
Agreed, It literally takes less than three minutes to pop the required panels, but ya gotta have faith........lolI don't know that they're different microphones. Neither worked when I pulled the fuse. You could try it yourself.
Also, popping a couple panels isn't "tearing into" the console.
Update.. now,mostly working, and by mostly.. 70%? When it gets lost, it's way off., like a mile or more. I have an email into the company looking for a solution. If I can't find a work around, it's coming out.
No guarantees in life, but yes.. this module is about as close as you can get. It disconnects the modem/cellular. If you don't care about the microphone, and I believe the right front speaker.. you can do this for free by pulling the DCM fuse.Reviving a bit of an old thread. How is this going for those who installed the kit? Also, so I'm clear, this would completely remove the possibility/risk of a 3rd party hacking into my vehicle - correct?
I read of the incident in Russia where newer Porsches were bricked remotely. Trying to avoid this type of risk. Thanks
