Let figure out a solution for disabling the DCM telematics - Silencing Antennas
Very curious to see how hard it is to install for someone inept like me.
Could it be easier to use the phone app to restrict your data privacy settings.
Absolutely easier, if you trust that by doing that they honor the settings.
Due to either greed or incompetence, many companies end up leaking data despite what some text in an app says.
If I trusted that it cut all ties to home office, which I don't. I don't want Toyota talking to my truck at all.
It seems simple enough to build but I just bought it.
I installed this today and it does indeed disable DCM, however, the microphone is still disconnected. I have an email out to the company, and I'll check the fuse and connections again later.
What is involved for the installation? How much, if any, of the console do you have to remove? Do they provide instructions?
No instructions other than unplugging dcm and plugging in the adapters.
It's easy. I used a single trim tool.
Both side knee pads.
Pull down shift boot, find little spring detent on bottom of shifter, push left and pop shifter off.
Pry up shift console, lay to side.
Using only a tug of the hand, pop off the drive mode select knob/buttons.
Then pry up console cover.
DCM is right there. Swap in adapters.
Reverse procedure.
I believe @EOD Guy posted the instructions somewhere on the site. Maybe the "interior" sub forum.
Okay, purchased and will give it a shot!
For those of you who go to purchase and cannot find the cart it claims to have just added to - turn off your ad blocker and then reload the page and add to cart again - then it works and shows the cart.
Can anybody who's already installed this tell me if you lose factory navigation
Good question, you might want to email the company. I installed this because I already lost factory navigation since I don't want to pay their subscription fee and thus, I don't want them talking to my truck at all.
I assume it will kill it since the little satellite symbol is slashed/greyed out after installing it and one of the points of this device (DCM module) is to support that function.
Installed today.. not a terribly difficult job. I removed the negative cable off the battery first. Also, have your head unit code ready to go when you hook the power back up. I did find the video below helped a bunch for the trim removal.
Why would you remove it. Is there an after market alternative that is better than the Toyota branded one?
