Husky Liner Issues? Anyone Else
Do you have pictures of the cub holders? We rarely have passengers but thinking these could be useful from the front also on road trips if they fit large water bottles?
We did have one bottle fall out of it, so it could use taller sides. I will say it’s convenient to hold a ranch cup from the pizza place for the drive home.😆 I wouldn’t trust it with open beverages while driving.
Amazon link: https://www.amazon.com/dp/B0FVXJHZLN?tag=landcruiserforum-20
You will definitely need to trim the lasfit second row mat. Shouldn’t be difficult since that section is pretty thin by comparison to the main foot sections, but the texturized ribs may be challenging. I bet you could trim shallow of what you need and heat roll a lip out if though. Good luck!
I had Husky liners in my Tahoe, and they had fit issues similar to what you show in those pictures. In the area where the rear floor liner went over the transmission hump, for example, there was enough room in the gap under the mat to slide in an Altoids tin.
I spoke to a Husky rep at the time. He admitted they had used published measurements from GM to size the mats on that model as they didn’t have access to an actual vehicle to do the laser measurements. Maybe they improved upon them later, not sure.
In any case -I had a similar experience.
I had this exact same issue when I got me 2027 and ordered the Husky Liners... I was pissed at first but I still like them better than then the stock or the Lastfits...
Yes, i bought the Husky liners because they fit so nicely in my GX460, i ended up returning them because how poorly they fit my LC250. Ended up with weathertech and they were fine in comparison, which is funny because I have weathertech in my 100 and 200 series and not a big fan of them. Doesn't seem like there is any consistency with these two companies on how well it will fit and work in your vehicle.
Mine fit fine, it took a few weeks of hot weather for them to calm down, this was back in 2025. I don't feel the quality is the same since RealTruck bought Husky. The F150 ones are a perfect fit, go figure.
