HUD
gregs
canada
2025 land cruiser
Hi, does anyone know how to adjust the heads up display?
We'll give you a pass since you're Canadian and we Land Cruiser drivers like Canadians....
Yes. Go into options and there is a settings features where you can adjust the height and brightness / etc.
Thanks, I searched around with the setting but could
Thanks, I tried the different settings but wasn’t able to raise the HUD, I’ll try again.
It does like some of the dashboard option sets, take a little time to be accustomed to...
Use the search feature here and find your answers.
If you need some "step by step" in accessing the menu that includes HUD adjustments, you start by using the arrow keys on the left side of the steering wheel.
Hit the left or right button near "OK" and watch for this in the centre of the instrument cluster:
Press and hold "OK" and then use the up or down arrow to get the settings icon to appear in the centre of the cluster:
Press "OK" and the menus should appear:
A short click of the "OK" button toggles it on or off, while a longer press of the "OK" button should get you into the menus:
Scrolling with the up/down buttons will allow you to change individual settings. I had to refresh my memory on all of this, as I haven't had to change much once I got settings dialled in the way I intended to keep them.
