Hello everyone,
I was reading through @EOD Guy 's thread and found this image:
How do I activate a load (say ham radio 50W + requiring 15A fuse) only when accessory mode of the vehicle is on?
My intuitive understanding is this:
I can connect the load directly to the battery, but I fear there might be some leakage current that might drain battery. Using accessory mode is ideal. Thank you!
- ACCY fuse taps don't actually supply power? Can I safely tap 15A circuit from this yellow marked area in an unused slot?
- If not, I would need a blue relay that supplies the power and it is activated using ACCY circuit? Similar to a transitor? How do I wire a new blue relay? I would also need the main load fuse in addition to ACCY fuse?
