For those of you who have installed solar on your LC, how do you address the instructions on page 550 of the manual to (a) never recharge when the hybrid system is on, and (b) have all accessories turned off. Do you only turn on the solar when the hybrid and accessories are off? Do you have a battery charge-current limiter or relays that only connect the solar charge controller to the battery when the hybrid and accessories are off? Do you ignore the warning?
One consideration is the warning on page 549 in the manual that the battery might explode if it is charged at a rate >5 amps. If the hybrid system is charging the battery at the approved rate, and then a solar panel provides an additional 5 amps (achievable with only ~60 watts), the charge will be 10 amps, double the specified max.
