Yes, I mentioned that the image you submitted is different than what is readily available off the shelf. You’d need to have a custom shop add in the “TRD” label if your heart is set on that. Good luckAppreciate the response. I did try reverse image search btw. I
I also appreciate the links, however those do not match the image that I submitted. I
I’ll see if I can connect with Darcy. Thanks!
Yeah, I’m not looking for the TRD. I just want the color to go under the rear window. The ones in the links provided do not do that.Yes, I mentioned that the image you submitted is different than what is readily available off the shelf. You’d need to have a custom shop add in the “TRD” label if your heart is set on that. Good luck
Cool best of luckYeah, I’m not looking for the TRD. I just want the color to go under the rear window. The ones in the links provided do not do that.
