GX550 Roof Rack on Land Cruiser
I bought a used GX550 roof rack, but I need the parts to mount it to my LC250 rails. I guess the Lexus owner had it mounted directly to their roof channel. Do you know where I might find the parts to help?
You likely bought the wrong version rack. The GX has 2 different roof racks. One for a low profile roof rail and the Overtrail roof rail (that is similar to the LC). The low profile roof rack screws into the low rail and the one you need has the integrated clamps for the raised rail. As far as I know, the attachment points are not available separately.
I think this is right because I almost did the same thing. The low-profile GX rack has bolt points that are not in the right place for the Land Cruiser roof - if you were able to mount that rack it would sit too far back and hang over the rear. This rack comes on any GX that is not an Overtrail.
The Overtrail rack has towers that clamp onto the side rails. That one works with the Land Cruiser, although be wary of clearance because I think the rack might be up there close to 7 feet up. 6’9” - 6’10” anyway.
It’s odd for Lexus to have two separate but largely visually identical roof racks IMO. It might be about more clearance on the Overtrail, who knows. In any case, if you already bought the non-Overtrail rack I think your only solution is to contact Lexus and see if they will sell you a set of the towers, which are proprietary. IIRC they are not listed separately for sale on the Lexus parts site.
Well I definitely wish I would’ve stumbled across this while searching.
I had a buddy pick up a rack on the way back home for me, well, turns out it’s the non overtrail version which bolts straight to the roof.
Has anyone had any luck getting the towers from Lexus?
Trying to do the same - but the roof rack on a gx550 can be installed three ways— 1) directly to roof 2) clamped to low side rails with a channel halfway on rail or 3) clamp fully to high side rails (like those on a Landcruiser). The rack I’m looking at comes with clamps for option 2. I need clamps for option 3. Anyone know the part number?
There are only two options, because #1 and #2 in your list are an amalgamation of one scenario.
I have your “option 2” which is the low profile rack attached to the roof via mounting footprints in the GX premium/premium +/luxury/luxury + “low-profile” roof rails. Option 1 is a misunderstanding created by OP simplifying the mounting method conversationally, but it’s the same as option 2.
Your “option 3” is using the standard roof rails on the LC and GX Overtrail/Overtrail +, and the roof rack specifically designed for the OT/OT +.
TLDR: you need the roof rack off of an OT or OT+. Hope that clears it up for you and helps.
As an aside, I am due to pickup an FE rack in a couple of weeks. Depending on your interest/flexibility, and of course location, I will have no need for my current setup. I only went this route because I thought my wife’s Sequoia’s TRD Pro rack had T-slots as well, which I found out was wrong two weekends ago.
Long story short, I put this together on the cheap with the help of some awesome members in here and have zero interest in turning a profit.
Sorry for not answering your actual question before. I had planned to circle back with the photos I had taken for my research on it, but the kids got off the bus and… life. Putting it here for anyone else confused or looking. Any questions, feel free to hit me up. The “low-profile” rack sits considerably further forward when compared to the OT rack. Above is an image of mine for reference, but the low-profile is almost centered front-to-back, where the OT rack sits in a more traditional 3/4 rack location.
OT Rack (If you have LC Roof Rails):
Prem/Prem+/Lux/Lux+ Rack (Need to source low profile rails):
Prem/Prem+/Lux/Lux+ Low-Profile Rails (I never cross-referenced the diagram # to a part # since a member in here hooked me up with his take-offs):
TLDR: you need the roof rack off of an OT or OT+. Hope that clears it up for you and helps.View attachment 51457
This is right. Lexus doesn’t sell the towers for the Overtrail rack separately. You have to buy the whole situation.
