Totally commend you on this project. May not like this comment, but….
think the juice isn’t a worth the squeeze.
The light output on mirror puddle lamp is pathetic. You can look close in your picture & see the LED element is tiny. I’d guess most LC Premium owners didn’t know that light was even there until your post.
I added 2 KC v2 Cyclones located at either end of the step rails using the step rail illumination circuit,, & that wasn’t for rock lights, but to improve the poor factory step rail entry/egress illumination. Until working on that system had never even noticed those puddle lamps.
While you have the mirror open you could cut the green/green black harness & add 12v & ground to the light side, so you could see them light up. If they’re like the step rail circuit the light is going to be polarity sensitive. Potentially if that worked you could run a wire harness up from your step rail circuit, through the door & into the mirror to power them.
Depends how thirsty you are my friend.
